Hansshow NACS to CCS1 Extension Cable
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
very true, limited to 100kW charging rate - but better than getting zero-kW while parked, waiting for a charger that can reach the truck charge-point IMHO.
In locations with huge DCFC stations with dozens of chargers, this may never be a problem, but in the places I travel, these stations are 4-6-8 ports only at this point. I hope more get built out sooner than later, but meanwhile I would be happy to pay a few hundred dollars for the 6-foot extension cord A2Z are working on.
I’ve never seen a 4 or 6 port Tesla station. They are always a multiple of 4 since that’s what each V3 cabinet will support and I don’t know of any single cabinet sites. Are there actually some 4 port V3 sites out there?
NW Ontario Ford Lightning
Robert
NW Ontario Canada
2024 F-150 SR Lightning XLT
Contractor
lots of them around here...hope they expand them over the next few years...
From my recent trip - I charged in Ignace Ontario ( a tiny northern town on the TransCanada Hwy system). From an online search:
Yes, there is a Tesla Supercharger (DCFC) station in Ignace, Ontario, located at the Ignace Town Plaza, 304 Main Street. The station features 6 Superchargers capable of up to 250kW and is available 24/7. This Supercharger is compatible with both Tesla vehicles and NACS-enabled vehicles with CCS capability.
During my trip to Winnipeg, there were sets of 6 Tesla DCFC in Ignace, Dryden and Kenora (Ontario) and in Prawda Manitoba. In the City of Winnipeg at Polo park mall that Tesla location was 8 chargers - multiple of 4 on that one. When I last travelled East all the Tesla stations where I charged were sets of 6.
In Canada we use different voltages than USA, ie your common 480volt AC is not used here generally, instead we use 347/600V 3P as a very common commercial voltage and above that is outside my experence, but I hear electricians discussing 4160v quite often. I suspect that a typical commercial service can support 6 Tesla EV fast charges, since this seems to be the common set up around here.
Robert
NW Ontario Canada
Contractor
Let us know how that works out.
It seems the truck already uses temperature monitoring in the charging system to reduce charging rate, from what we have seen on the forum. ie this is why you start off on a DCFC at very high current but only for 6-12 minutes or so, then it gradually reduces. The extension cord will increase resistence and therefore temperature and the truck will respond ? yes/no?
The sensor is in the charge port. The truck (or the charging station) has no clue what’s happening along that extension cord.
The normal throttling you observe is either part of the charge curve or battery thermal management. Under normal operation, throttling due to over temp at the charge port does not occur. In fact, a charge port over temp sets a DTC.
21st Century Truck
Martin
A side note for Tesla Supercharger station cord evolution... I just completed a 9,300+ mile two month trip during which we used Tesla as well as CCS DC Fast charging stations, as needed.
We actually tripped into two (out of at least 20) Tesla locations where the Supercharger cords were of "CCS normal" useful lengths... so Supercharger cord change IS coming, albeit slowly.
I wouldn't be concerned, personally, about any 'safety' issue, as these connections look very secure and beefy, just like the NACS plug and the Adapters we already use... but, I'll in no way be paying that kind of price for such a short cable, and very, very infrequent 'need' for one...if ever. I've never had any issue finding a way to reach a Supercharger cable... even with our camper in tow.
tls
New York
2022 Lightning
The Hansshow "80A" AC charging adapter *looks* very "secure and beefy" too, but as noted in the post linked above, when disassembled (or when it disassembles itself, also as described in the linked post) it turns out to be incredibly dangerous garbage. And Hansshow clearly know it, too, since they won't provide meaningful support (an invitation to connect on some sketchy Chinese chat app and then complete refusal to assist by email or phone). My guess? They are probably trying to limit the exposure of anyone in the US or Europe associated with their products so when they finally burn someone's house or car to the ground, they have a better shot at avoiding liability.
Just the specs of this CCS extension cable - which I'd strongly suspect it does not meet - are hair-raising. Rated to 250A when there's no way it can enforce that, and most 400V vehicles at a compatible Supercharger will draw far more?
Another one of this company's big products was a powered-open kit for the Tesla frunk that jammed people's hood open so they couldn't drive. Trust them to safely put 200kW of power into the charge port of my truck? Thanks, no.
carys98
Cary
Raleigh, NC
Retired EE
I was able to find some pictures of the Ignace site on the Tesla supercharger.info site. I looks like they are only running 3 dispensers per cabinet based on the conduit runs. They also have 2 transformers at the site so each cabinet seems to get its own. I wonder if it is something uniquely Canadian or if there are 6 dispenser sites in the US. I have some new questions for the next time I talk to my Tesla experts.
https://teslamotorsclub.com/tmc/threads/supercharger-ignace-on.170491/
carys98
Cary
Raleigh, NC
Retired EE
Yes they are probably secure but if you push the button on the NACS end it will allow you to unplug it. If you do that without stopping the charge you could get an arc flash which best case burns you and worst case kills you. The solution is a 10 cent microswitch that they seem resistant to adding.
