VAL.ABAPO
My attempt with your design using PETG-GFI didn't, well, until now that is.
My first print turned into a birdsnest halfway through, so I had to start over.
I modified the tub slightly so that it accepts the Bronco shifter as well, top one is Escape and bottom is Bronco (same tub) and it also does E-Transit (which is the one I'm using). Escape and E-Transit fits better due to their chamfered top whereas the Bronco shifter is straight, so visually there's a slightly bigger gap around the knob.
I'm using M4 metal inserts from this kit >> https://www.amazon.com/dp/B0CPVCTXJ7?th=1
Others may work, but this is what I used on mine. I'd use flanged M4x12 screws, but regular M4+washers is OK too.
When mounting it in the truck you need to undo the gray plastic clip in the back left hand side wall holding the cable in place. Because the support bracket end up right behind / underneath the connector you also need to plug the cable into the shifter before you attach the front support.
For the very same reason you can't use the center mounting bolt, it's too tight to get to it (at least for me, but don't worry, it's not going anywhere with the three that's there.
If you feel generous, go here >> https://www.thingiverse.com/thing:6978586/files and tip @ENDianDigital, it's only because he started it and was kind enough to publish his step files that I even thought about doing this, so credit goes to him.
This ZIP-File has the Step files and the STL files that I used to print the one below.
I'm by no means a mechanical designer, so this isn't optimized for anything except that it works for me. My print took 60hrs (0.12mm layer height and 20% infill), so be prepared to wait.
