Spare tire question
Highpi
Ken
Sacramento, Ca.
2025 Lightning Lariat, Iconic Silver
I'm a bit confused about spare tires. Some on here have a regular tire as a spare and but a dealer told me I need a similar EV tire due to the weight.
Can I get by just buying a 20" wheel and same size tire as what is currently on my Lariat? Say, something off an Expedition or an ICE 150?
Athrun88
Toronto, Ontario, Canada
My 2024 Lariat has a 18in spare. Had to throw it on when I got a flat on the highway. Not a full tread spare, but enough to get to where you need to go. I was able to get home and plug my full size.
Im sure you could store a full size under there if you wanted.
K6CCC
Glendora, Calif.
Two Way radio systems
My 2024 Flash came with a spare that appeared to be the same as the four on the ground.
rdr854
Northern Virginia
The answer is yes. I have a 2022 Lariat and replaced the spare with a matching 20” wheel and tire so I have 5 matching tires and wheels on the truck. Also put in the TPMS on the spare.
Old Aviator
Larry
WPB, FL
Consultant
I have a Platinum and a 22" Platinum will fit in the spare wheel well. Did not try to program TPM. Can the system actually monitor 5 wheels? I have programing tool I'll be all over that if it can be done.
21st Century Truck
Martin
Yes the spare wheel hole can accomodate a full-size OEM wheel and tire. I got one in there.
Its TPMS is "silent" until the spare wheel is mounted on an axle and begins to rotate... so there is no worry about whether the truck's display system can, or needs to, read the spare wheel's TPMS sensor until it's needed.
I hope this info helps.
Highpi
Ken
Sacramento, Ca.
Did you buy the OEM wheel? There a bit pricey from the dealer.
Highpi
Ken
Sacramento, Ca.
That was going to be my next question, thanks.
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
The "EV" tires that came on mine are flimsy, lightweight, and have a 50 PSI max pressure just like every P-rated light truck tire I've seen in the last 30 years. Nothing special about them. The rubber compound is also low durometer, i.e. soft and squishy like a standard P-rated tire. So, just use any tire of the correct size you want to.
Do you need a new spare tire? Do new trucks not come with a spare?
Zed
Chuck
2022 Lightning Platinum Rapid Red
Spare tires are optional on 2025+ Lightnings. Not sure if the ICE trucks are the same.
Robert1380
Robert
Retired law enforcement
my 2025 Platinum at 88 grand didn’t. And it didn’t come with Homelink to open the garage door.
21st Century Truck
Martin
Those who need the OEM spare, full-size limited use wheel + tire, I listed mine in the FOR SALE forum section.
