krazyrunner86
So I have a 22' Platinum that has been pretty reliable overall. I did have to have a battery module replaced last summer for the reduced power error, but that was resolved without much fuss. The only other problem I had was regarding the truck communicating with the Ford Pass app, which was finally resolved(seemingly) after replacing the 12v battery with an Ohmmu lithium. However on Monday I had a not so pleasant experience.
I was driving a family member to a medical appt in the early morning. We left the house and as I was driving out of the neighborhood, I thought I felt the rear wheels slip. It had been cold, so I just thought it was a little patch of ice. When I got onto a main road, I started feeling similar sensations, only the road was very clearly dry/salted without any ice. It was happening every 30 ish seconds or so, and as I paid more attention, it felt like the truck would lose propulsion for a split second, or that the regen would kick in for a split second. Very strange. After a few minutes of going 40+ mph, the sensations started getting more frequent, and my passenger commented on it. At that point I started hearing intermittent buzzing/crackling/popping sounds, seemingly coming from the passenger side rear wheel/axle area, but definitely from under the truck.
Within a minute the buzzing got a little louder and was continuous. The slips/power loss was happening every few seconds, and then a powertrain error message flashed on the screen. I was in the process of pulling over when the regen braking stopped working and the truck just coasted. I tried to accelerate a little bit to make it to a parking lot, but the accelerator did nothing when depressed, so we just kind of rolled to a stop. I turned the truck off, waited 10 seconds, and then turned it back on. The red wrench was illuminated on the dash, but the truck started moving when I hit the pedal, so we turned around and headed back to the house.
On the way, we basically went through the same sequence of events, but we were able to get into the driveway without complete power loss at least. I parked it, turned it off, and we used another vehicle to go to the appointment.
Later that morning, I decided to try and drive the truck to the Ford dealer(~5 miles away) instead of calling for a tow. I normally use Sport mode, but I turned it to Normal and turned off the regen braking, just to see if that makes a difference. Red wrench light still on, and same sequence of events occurred again. I had to pull over about a mile into my drive, turn it off and on again. After starting on my way once more, the problems happened much more rapidly and I only was able to make it about 300 yards down the road before I had a complete power loss again. This time just about every error message imaginable flashed on the dash. Adaptive cruise, parking sensors, cameras, regen braking, etc etc etc. Everytime I dismissed an error message another popped up. There were sounds playing with the messages, and they just kept cycling through even after being dismissed. Turning on the 360 degree camera showed a normal picture for a second, then it flashed green, then black, then it showed images for just the front and back, then sides, then green again, round and round with glitchy video.
At this point, I turned it off again, waited a full minute, and turned it back on. Error messages start cycling again right away, and no propulsion, accelerator does nothing. I turned it off, waited 5 minutes before turning it on again, same thing. Ended up turning it off again, and calling for a tow. I sat there for almost 30 minutes before the tow company let me know it would be another 2 hours before they could get there. I figured, may as well try again, so I turned it on, and just like that, no errors, red wrench gone, and it goes when i hit the accelerator.
I decide to try and drive the rest of the way really slow, so I turn on my hazards and drive less than 25 mph the entire way. Truck is behaving normally, no sounds, no weird jerks or slips, no error messages, nothing. Pull in, tell the techs this whole story, and go home with a rental. The next day they call me and say that they drove it, and it seems fine, no problems. I ask if they tested it in Sport mode, with regen on/off, and they did not, so they took it back out again. They call me and say they thought they might have heard a weird noise, but it was quiet and seemed to be coming from the front of the truck. They put it on a jack and tried to recreate the noise with it in the air, and nothing. Sounds normal, behaves normal, just normal normal normal.
I picked it back up today. I took it around town stop and go traffic. I jack-rabbited some starts and tried some abrupt stops. I tried so slow starts and gradual stops. I took it on the freeway fast and slow, up and downs hills, through some potholes/bumps, anything I could think of. Its running absolutely perfectly.
So I don't know what to make of this. Has anyone had anything like this before??? I was legit worried that something serious had broken or malfunctioned and now it's completely normal without any intervention at all. I'm at a loss, but I'm still nervous that this problem will randomly crop up again. I drive quite a bit for work, and I don't want this to happen on the freeway in the boonies, leaving me stranded for who knows how long. Really hoping someone has some insights into this they could share. Thanks.
