$200 48amp Amazon charger
TMND
usa
Lightning
ag
Got this as a black Friday deal for $204. Plug it in and it works pretty straightforward. The app is not proprietary or necessary (it has RFID cards). It’s just some third-party app for managing a connected home called smart life. Non-coincidentally I can’t find any information about country of origin on the packaging the instructions or the website. Pretty sure I have a good guess though. 😉
Charging at 46 A and 234 V giving me 10.8 kW. Hoping it holds and this turns out to be a good little unit.
Ford F-150 Lightning $200 48amp Amazon charger IMG_7004
Ford F-150 Lightning $200 48amp Amazon charger IMG_7006
Runaway Tractor
Yes
Buying high voltage, high current equipment from chinesium fake brands on Amazon is a very very bad idea. There is no such company as Jeekvisen. It has no certifications (UL, ETL, etc). It is made with inferior conductors. There is a high probability of it burning down your house.
I recommend you return it to Amazon right away and stop using it.
TMND
TMND
usa
Lightning
ag
Oh, I would like to have made a better choice, but with things not going my way the last six months, water heater went out, washer and dryer broke, and xmas coming has soured my budget a little and ford warranty isn’t helping me with the fact that the charger that came with the truck sucks.
I need to be able to charge this truck closest fast charger is 50 miles away. And fast charging is more expensive than gas at this point.
This is at work in a shop and I am able to monitor it whenever I’m using it because it’s in my workspace. I’ll update any changes.
If it’s charging at 46A and uses the plug shown in the picture, you have the makings of a pyrotechnic time bomb waiting to go off. Especially if you have a cheap, Home Depot special receptacle.
TMND
TMND
usa
Lightning
ag
We run welders all day off of these outlets. If that was the case wouldn’t the plug on the welder explode. I’m no electrician, but I’m assuming the welder that’s melting half inch plate is drawing probably more amps than 48. I turned it down to 40 anyways.
A welder is very intermittent duty and draws much less current than one might think.
40A would be the maximum allowed for charging from a 50A circuit per the NEC (80% of 50A).
Dont just take my word for it:
https://www.macheforum.com/site/thr...-charging-equipment.40121/page-15#post-875216
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
TMND
TMND
usa
Lightning
ag
You’re not wrong it’s never plugged for more than three hours at a time at work lol. I already had a sneaking suspicion It shouldn’t run at 48 even though it has the capability seeing as any other 48 amp charger says it needs to be hardwired though this says that nowhere.
I’ll keep it at 40 or less only turn into 40 when I need the full juice. But next time our electricians here I’ll get his thoughts. I don’t like the location right now. Maybe I can get the company to foot the bill to hardwire it closer to the panel.
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
OP, I would highly suggest returning this and buying from a known brand. A fire risk is not worth it.
Newton
WA State
Figure out how much charge you actually need over the time that you have the charger in use and dial it down to that level. Assuming 2 mi/kWh you have roughly (it will be less depending on where in the charge curve you are)
  • 15 A: 3.6 kW (3.6kW/240V = 15A) = 7.2 mi/Hr 7Hrs = 50 miles
  • 30 A: 7.2 kW (7.2kW/240V = 30A) = 14.4 mi/Hr 7Hrs = 100 miles
  • 40 A: 9.6 kW (9.6kW/240V = 40A) = 19.2 mi/Hr. 7Hrs = 134 miles
  • 48 A: 11.5 kW (11.5kW/240V = 48A) = 23.0 mi/Hr. 7Hrs = 161 miles
For example, If you drive less than 25 miles to work and have 7 hours to charge, you could get away with dialing it way down to 15 amps which would negate a lot of the concerns about the quality of the equipment. Honestly I‘m not so worried about the made in china aspect (their EVs are light years ahead of ours) but the lack of certification is a worry.
Newton
WA State
I think it is made by Sino (Zhuhai Sino Energy Co., Ltd.) but you can never tell if they are just putting their name on it or vice-versa. They do have some videos and stuff that might be useful for you.
