2021+ Ford F-150 - Steering Column Shifter
LSUT1GER
Slidell, LA
Computer Engineer
2021+ Ford F-150 - Steering Column Shifter Teaser - Infotainment.com
Key Features Come to Life in Your F-150: 🔄 100% Plug-and-Play — Quick install in about 30 minutes 🛠 No Column Swap Needed — Keep your original column intact 📦 Center Console Fully Usable — Fold-out console works for laptops and storage ✨ OEM-Look Pocket Conversion — Looks just like factory ⚡ Quick Plastic Swap & Mount — Minimal parts, maximum ease
Upgrade your truck with a column shifter that feels like it came from the factory, keeps your center console usable, and installs in a snap! Your input drives our innovation! Interested in more DIY, plug-n-play, OEM upgrades for your vehicle? Let us know what you want by CLICKING HERE: https://infotainment.com/product-live...
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Platinum
We had a lot of interest in this. They worked hard to figure out a bracket that was secure enough to allow the installation of the column shifter without having to replace the column.
We are working to have an optional Genie Maxx to allow mode selection from the plus and minus buttons that were for gear change. You would be able to scroll through modes or assign specific mode.
That will be after the initial conversion ships.
priceb
Price
Western North Carolina
2023 F150 Lightning XLT
College Instructor
This is exciting. I look forward to being able to make use of the folding work surface while not in park and not having to fold it to change gears.
Jesse-Infotainment
Jesse
Dallas
They have a 24 Lightning XLT in FLorida now also. I talked them into buying one.. we will be working towards more kits for the Lightning.
this is a good option versus the update to a Rotary Dial, but, regardless, if trying to justify either just to make use of the 'folding desk' option, you still have the same issues:
what to do with all that 'stuff', such, as water bottles, coffee mugs, etc, that are now going to still be 'in the way'.....
SpaceEVDriver
Arizona
I’m about a week away from doing the dial upgrade, but if the column shifter is ever made readily available and affordable, I’ll serious consider it.
tls
New York
2022 Lightning
I want one of these, I will totally buy one if they're reasonably priced and maybe even if not, and I am hoping @Jesse-Infotainment gets a decent chunk of change for his work on this and all the other ways he helps our community.
What happens to the folding shifter when this is installed? Does it remain in place but become unusable, or do they both work (that'd be pretty weird, seeing it move when the column shifter is used to select a new gear!).
Only hitch for me is that I've needed one clock spring replacement already due to the "honking" problem and after a year, the "honk" has come back when turning the wheel at low speed so I know I'll need another. I hope this wouldn't make my dealership (who are really pretty good) not want to fix that as warranty work.
Jesse-Infotainment
Jesse
Dallas
We would include the tub that the ICE trucks have when they come with the column shifter. Im sure we as a company would potentially buy the shifter back also.
"Only hitch for me is that I've needed one clock spring replacement already due to the "honking" problem and after a year, the "honk" has come back when turning the wheel at low speed so I know I'll need another. I hope this wouldn't make my dealership (who are really pretty good) not want to fix that as warranty work."
As far as this.. Dealers will do what dealers do. We cant really give you an idea of what to expect.. they are so different from one to another. Ive seen some have no problem as long as that didnt cause the issue while some dealers blame oil leaks on screen upgrades.
RipInPepz
Erik
Ohio
2025 Flash Antimatter Blue - 131kWh ER, 9.6kW PPOB
This would be a game changer...
Ford F-150 Lightning 2021+ Ford F-150 - Steering Column Shifter asdfasf
S. E. Louisiana
Auto tech
Every truck I've owned had the column shifter including one old GMC 3/4T with a manual "3 on the tree" that loved to hangup if you shifted too fast. Along comes the Lightning with the sportier console shifter and I like it much better, gives me a place to rest my hand while driving lol.
I don't have the fold flat work space console lid so that isn't a consideration either. I suppose I'd buy one to replace the floor shifter if it was less cost than the rotary knob or a direct replacement floor shifter.
I guess you could call me neutral as far as any of them go so long as it gets me point A to B, the winner being the better made unit and of course cost.
fsantos
Froi
Hamilton
F150 Lightning
Are you able to upgrade my Lightning to the flip-up 6th seat as well?
Will this shifter be compatible with the Lariat and Platinum models with the memory columns?
