2025 bricked at 1000 miles
I’ll be honest I have zero idea what that means 😂
Under "ideal" conditions your truck has an estimated range of 320 miles, versus the newer ER which only go about 300 miles, things of trivia since given how most of us do not drive in ideal conditions, we never see these values on a regular basis.
In the past, I've bought a brand new Duralast Gold battery from AutoZone and it turned out to be a dud. So a brand new 12v battery failing is a possibility.
Maxx
Anyone close by with a jumper cable should be able to help test that theory.
Voltmeter or OBDII reader could also provide additional clues as to 12v SOC. Could also look up which error codes are getting thrown.
BSEE SPARKY
Derek
Southern Indiana
2023 Lightning Lariat ER, MAX TOW, Power Running Boards
I am a long way from being an expert or even an amateur, but if it starts goes a few minutes then fails. It sounds like the DC to DC Converter is not working. Therefore the 12 vDC battery doesn't have a way to charge after start up and it can't last very long on its own
jetfixr1
Manny
Atlanta
So dealership said most likely a faulty junction box. Known issue they’ve seen and thought should be fixed on a 25 but apparently not. We will see.
You know, the great (maybe not so great in your POV) thing about electronics is their bathtub curve. You either have infant mortality or you dont. Basically, electronics will either break at the very beginning of their service life or die a miserable death at the very end when its all worn out. You ideally want the latter but having the former isnt too bad either. Its my way of saying that you should hopefully not run into any other issues after this one; enjoy your truck!
Thunderand…
Patrick
2025 Lightning Flash
FireFighter
I did ask them that specifically, if this issue typically comes back. They said nope that the replacement is an updated part and shouldn’t break again. Fingers crossed
jetfixr1
Manny
Atlanta
Whenever they give you the service report which shows the DTC that popped up and part they replaced may you kindly upload it here.
edit: Im also wondering which part this is. Other than the Gear Shift Module always being a problem, im not aware of any parts that has been an issue on previous lightnings which ford has carried over into the 25 models. The HVBJB was an issue on MMEs which Ford carried over a couple of years but eventually released an updated part. Not saying he is referencing that but now im curious.
Agree. I’m not aware of an update to the HVBJB on the Lightning.
Please share the work order after the service is complete, interested in seeing the part number they specified in the job compared to what is shown in parts supply online
tubby
Press
Iowa
The phrase suggests that your vehicle is from an initial production run ("Job-1") and is equipped with a high voltage battery (HVB) that supports an electric motor with a power output of 131 kW (approximately 175.54 580 hp).
