26C10 Trailer Module Reprogramming NHTSA#26V104
I'm getting my trailer module update done Wednesday morning 3/25 dropping the Lightning off in the morning, they're doing the 30k at that time also.
bc1
McPherson, KS
I'm not sure what the deal is here. If it has been working fine in the past and there is a communication problem at startup, can't you shut down and restart until it does run without the communication failure?
jamelski
Sacramento
2024 Lariat
I finally reached out to the mobile repair tech and they checked for the trailer recall but I have already received the over the update the OBBC-AS.AU update which also does the recall it has been removed from Ford Pass.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Probably. That’s why it’s called a race condition, you never know who’s going to win. The problem is if you don’t notice the warning when it pops up you will be driving around without working trailers lights.
oldman_74
Bob
Central Florida
2024 Lightning Flash
Ford just came to my home today and spent about 30 minutes both recalls and the 10K mile maintenance. No cost to me. It was a pleasure to see how this all came together.
Got my truck back from service this afternoon, they completed the 26c10 updates with no issues, also did the multipoint inspection, the coolant testing was fine and they rotated the tires, while the 25c69 recall could NOT be completed do to lack of software for 2022 & 2023 Lightnings.
Final cost for services $44.
abcut973
Anthony
Denham Springs
I do have this recall as well now in the fordpass app. I'll just wait for the OTA as I don't tow much.
bydabeach
NJ
Lighting Lariat ER; Volvo S60 Recharge
I have a 2022. I did a search in Grok, and it advised:
"Brake fluid replacement: Every 3 years (do not exceed this; requires dealer equipment). Regenerative braking in the Lightning reduces brake wear, but fluid still degrades over time." This checks with what the service schedule says.
How much does the dealer charge for this?
https://www.fordservicecontent.com/...A&div=f&vFilteringEnabled=False&buildtype=web
ka-chow
Scott
2023 Lightning XLT
DJ
I guess I’m just waiting for the OTH update for this as I have a 23 model and also have towed (at least) a hundred times without experiencing these problems.
spacepirate
Ken
Middle-of, CT, USA
2024 F150 Lightning Flash
Dealership called me a couple of days ago and offered to come by and do it in my driveway. It only took the guy about 10-15 minutes and I've had no issues. He said that the update had not been released OTA yet and they were just trying to get ahead of it by mobile service visits.
I found it interesting that the tech said that he had gear in his truck to charge mine if it was needed(it wasn't). Does anyone know if they do this via a generator or do they carry a battery around to top folks off?
Probably on a related note, the truck now wants to apply the OTA update that others have started getting related to public charging. It was supposed to do it last night but didn't because it says the update process was interrupted so it will try again tonight.
LUXMAN
F150 Lightning PRO and XLT
Pilot
What coolant testing did you har done? Not familiar with this ?
SFsparkie
2023 F150 Lightning Lariat ER 01/23
Mobile service in my driveway
Recalls 26C10 & 25V69 completed in 30min
‘23 lariat. Dealer said no fix for 25SB6 yet
flyct
Jerry
South Florida
Blissfully Retired
I had Ford Mobile service come out and do the Trailer Light software recall last week in my driveway.
Tonight i went to pick up my Enclosed trailer from new house and after hooking it up to the truck I found that running lights, trailer interior light and parking lights don't work. The only lights that work when testing was wither turn signal and both brake lights when running through the trailer test routine with the phone App. Being that it was dark outside now, I had to leave the trailer behind since the tail lights and running lights were not working.
The truck sensed that the 4-wire trailer plug was connected and I selected the default trailer. Does anyone know what signal line that ford uses to sense connection?
Tomorrow I will go and pick it up with my Tesla during daylight hours. I'll also bring a trailer test setup to isolate the truck and trailer as a fault.
UGH!!!
