What is the adapter needed to connect the included charging cable to the 240v connector in the bed?
thorndike
Robert
Colorado
2023 F150 Lightning Platinum
Since we are now a two EV family, I wanted to take advantage of the 240v connector in the bed to be able to charger our Ioniq 5 in case of an emergency. I just learned about this capability tonight and wanted to know about the connector needed to connect the charging cable to the outlet. Is this a standard, readily available connector, or do I have to build it? Thanks!
queuewho
Western PA
22 F150 Lightning Lariat SR
Wondering what happens if you plug in something that uses the full 50 amps into one of these while connected to the truck. I assume the Ford EVSE works fine since it is rated for 30 amps.
Heliian
Probably not. The Ford mobile power cord draws 32a continuous at 240v and would need a 40a breaker minimum, Ford recommends 50a breaker as it uses a 50a plug.
Better off using something below 30a, many adjustable evse on the market now.
Blainestang
FL
F56, R55, Pro
My truck which was delivered on 10/2/23 came with this adapter.
Interesting!
I didn't get one in late 2022.
Maybe me and the thread starter are the outliers, but I didn't think they were still giving these out!
Interesting!
Mine was a dealer demo, June '22 build and I purchased in Feb '23. Did not have any adapter either.
jefrank
Jeff
Fenton, Michigan
2022 Ford F-150 Lightning Lariat, 2004 BMW 330Ci
Interesting!
I didn't get one with my late-August, 2022 delivery, either
16cards
North Carolina
MY23 Lightning Lariat ER
The 240V receptacle / outlet is L14-30P.
Amps
Mid-Atlantic
Bolt
I *believe* this is the adapter that Ford itself provided with some of the earliest Lightnings:
https://www.amazon.com/gp/product/B07XQFN8RK/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1
That Parkworld is the adapter Ford provided, along with a J1772 to Tesla adapter with a very few early Lightning deliveries. Personally, I'd always use a dogbone style adapter to reduce stress on the bed receptacle. A locking plug reduces the need, but the stress still goes to the receptacle when plugging and unplugging and moving the EVSE plugged into the L14-50.
jdmackes
2023 F-150 Lightning Pro
Interesting!
Didn't get one with my Pro I purchased in May either
