Charge Station Pro Charge Rate Slowing Down
ranger5ft21
Rick
2023 F150 Lightning Lariat ER
When I originally got the charge station pro installed, I was getting about 41-43 added miles per hour, but recently I've noticed I'm only getting about 30-31 added miles for hour. With the new charge rate, I've noticed the charger kicks on and off throughout the charge session. I'll be honest, I didn't pay much attention to whether it did that before, but it seems like it's doing it more often which is leading to a slower charge rate. Does anyone know a couple troubleshooting ideas to get back to the original rate? No settings on the charge station have been adjusted since the install. I'm not sure if it's the truck, the charge station, wire for the charge station, electrical company slowing service in the summer, etc.
Any help is appreciated!
Heliian
First, turn off charger breaker for 5 minutes and then turn back on.
Are you somewhere hot? Heat slows it down.
ranger5ft21
Rick
I'll give this a try when I get home later tonight. I'm in the mid-atlantic region, so we get high 90s in the summer.
What does FordPass show for a charge rate in KW? Stating a charge rate in mph is subjective, at best.
ranger5ft21
Rick
I know when it was first installed in was 17 kWh, but I think recently it's been about 13 kWh. The charge logs don't keep the kWh, it just keeps the time charged and how many miles. If my math is right it translates to ~41 miles added (17 <charge rate> / 131 <capacity> * 320 <avg range>) and ~31 miles (13 <charge rate> / 131 <capacity> * 320 <avg range>). I never synced the CSP with my FordPass account (planning to do that this week), so hopefully I'll be able to get more data when charging like efficiency.
I need to charge it tonight when I get home, so I will verify the charge rate then.
I wouldn't think the temperature would play a major factor since I charge at night and it's in the 70s.
Look at the lights on the charger, then look them up in the charger manual.
Dial it down in amperage when you find out it's overheating.
