branden
Branden
'22 Lightning Lariat ER
Since you drive a lot, what model and settings are you using (PC blend high/low, pid gain)
Did the BP Portal from 5.0 change? Was just looking at it on 6.0.1 and all I see is the Parameters page which is a pain to navigate.
I keep all my settings default on LCD model
PJnc284
Garner, NC
I am curious why you choose OP Long over Ford ACC.
It seems to be a lot less reactive to people merging in front of you or turning. I generally use regular ACC since it likes to give random brake checks on a couple mile stretch on my normal route to work though.
Ajzride
Alan
Houston
Eng
The settings are in sunnylink now, so I didn't duplicate them in the bp portal.
PJnc284
Garner, NC
Sunnylink is ok but has a lot of clutter. It connects but didn't appear to reflect some of the values set on the device. The good thing about the BP Portal was the ability to set favorites.
Sidenote I updated to 6.0.1 last night after uninstalling 6.0 and it seems to be stuck on the home screen that shows your trip info. Selected 22/23 Lightning under Vehicles but no change. Reset and same behavior. Didn't have much time to mess with it this morning but will poke around more this afternoon
Ajzride
Alan
Houston
Eng
The good news is, both versions are open source. You can port it yourself and submit a PR so everyone can enjoy it. Or, offer up a bounty to get someone else to do it.
It didn't get a crash report, so nothing is causing the inroad UI to not launch. Triple check all the usb plugs are tight. Mine was doing the same thing the other night and I realized the USB cable in my dock had started to deform and had shrunk back a little and it wasn't making full contact. I had to open the dock up and reposition the cable, and secure it with a little glue
ZheWiz
Jack
Central NY State
2023 F150 Lariat ER. Less Tech than CT 😘
Database Developer
Are you using ford ACC or OP long?
Can someone translate this question? :) What is "OP Long"? I assume "Open Pilot" but "Long?" What is "Long?" And "Ford ACC" is BlueCruise?
How do you "select" which one you want to use? Some of this MAY be obvious once I hook this thing up, but right now it's still on my desk waiting for warmer, 3M friendly weather. All these TLAs are messing with my head. :)
B177y
Bill
Olympic Peninsula, WA
OP Long = Open Pilot longitudinal control - forward longitudinal control instead of side-to-side lateral control.. This is OpenPilot (or BluePilot (BP) or SunnyPilot (SP), etc...) control of adaptive cruise control. Also working towards ability to stop at red lights, stop signs, etc. Still considered "experimental".
Ford ACC = Ford Adaptive Cruise Control. Using Ford's built in adaptive cruise. Also called "hands-on bluecruise (BC)". The "hands-off bluecruise" is not used and not necessary to have when using a Comma. Minimum requirements to use Comma in Fords is ACC with lane centering ability. Lane keeping on most stock Pro and XLT trims will not work with a Comma without adding a radar module and some Forscan work.
Ford ACC is the default. When you set your cruise control with the Comma on and running, the Ford ACC controls the speed and the Comma controls the lateral control (steering) through the lane centering system similar to hands-off bluecruise, but much better and available on any road, not BC mapped roads only.
You select OP Long in the Comma settings by toggling on "experimental mode" in the Comma, then toggling on "OpenPilot Longitudinal Control". Different versions of OP/BP/SP have similar but slightly different locations in the Comma settings. Now when you activate your cruise control, the ACC portion is controlled by Comma, not the Ford.
EDIT - OP Long correction from @Ajzride :
You first tun on "OpenPilot Longitudinal Control" or "Alpha Long" (it depends on whether you are doing on your device or in sunnylink what the name is. I have a request to make the name consistent between the two). This gives comma control of the gas and brake, and it will operate like standard ACC. You can then turn on experimental mode, which adds stop signs and red light functionality (that works about 50% of the time).
Some prefer the Ford ACC better. I like Ford ACC and use it all the time with Comma controlling the lateral. Some prefer OP Long. It's your choice.
A draft owners manual is in the works. I'll suggest that there is a TLA translation page included ;)
Ajzride
Alan
Houston
Eng
Slight correction here:
B177y
Bill
Quoted and added to my post for clarity in case someone searches. Thanks!
Reactions: EVO
ZheWiz
Jack
Central NY State
Database Developer
Thank you (both) for the excellent explanation!
PJnc284
Garner, NC
Got in this afternoon and it went to driving mode but the dash lit up like a Christmas tree. Reseated the comma and unplugged the cord and 90 from the dock and all is well now.
BluesClues
2022 f150 lightning sr lariat
you still want the offset bracket, or your c4 will be all up in the middle of your FCX field of view.
by the way if you make a combo c4 dock and fitcam offset, I would buy!
Ajzride
Alan
Houston
Eng
to elaborate on my quick phone response from earlier.
I initially set out to make a combo unit. But by time you get the camera far enough away from the comma that it’s not in the field of view, you have a big unit that is either overly heavily and bulky to ship and will take up a bunch of dead space, or has long flimsy branches that might break
and can’t really support the devices well.
I also looked at stacking them vertically, but that has even more issues.
two separate mounts is what makes sense.
