UncleTony
For clarity, you are saying you had the issue even with the lightning coupler (with the resistor) until you replaced your cabling?I just wanted to briefly comment on this. I had tons of issues with the AC at first with my 2024 lightning. I had try a ton of long USB C cables until I found one that worked. Eventually I got it worked out. I’m now currently using the one out of the F150 kit that comma sent once I got the new coupler. But that did not work prior to that. Another thing to note is that the couple that comes in the quick release dock will not allow my AC to work at all. I’ve always had to bypass it going directly into the comma.
