EVO
Randy
Leavenworth, Kansas
2024 lightning flash
electrician
toggle on the radar overlay and it will show you distance and time to the vehicle in front of you
Yeah I do have that toggled on. I turned off pretty much all the other visuals because of the heat issues with the 3x.
Laphuks
2024 F150 Lightning Lariat
Would comma 4 running BP7 stops on stop signs? Where do u set it up?
Ajzride
Alan
Houston
Eng
It will try, don’t expect it to succeed.
use sunnylink to search for “alpha long” or “sunnypilot long”. Turn that on and then enable “experimental mode”
NeighborGeek
2025 F150 Lightning Flash
It can, but only if you are using the comma to control acceleration and braking. The general recommendation I've seen has been to let Ford's adaptive cruise control handle that, and bluepilot handles only the steering. (AKA, do not enable experimental mode / longitudinal control on the comma) If you follow that recommendation, the comma isn't controlling stops and starts, so even if it sees a stop sign/light it can't do anything about it.
I've enabled experimental mode on the comma in my wife's bolt, and it seems to work well enough. I'm not sure why they say to stick with the vehicle's ACC on fords, but I've followed the recommendation so far.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Hey everyone,
Quick heads-up: we're discontinuing the Lightning Coupler once this batch sells out.
Orders have dropped off sharply over the last stretch, and these have to be ordered a few hundred at a time. Sitting on that much inventory at current demand doesn't make sense, and small-batch ordering after import costs would mean raising the price to a point I'm not comfortable with.
If you want one, the order links are below:
Coupler: https://bluepilot.dev/lightning-coupler-order-page/
Dock with integrated coupler: https://bluepilot.dev/dock-order-page/
I can't estimate how long the remaining stock will last, so order sooner rather than later if you need one or want a spare.
ugold
Lars
2024 F-150 Lightning Lariat
Hey everyone,
Thanks for the heads up. I ordered a spare just in case. I accidentally busted the development one you sent me awhile ago and luckily already had the final production unit so I just swapped it in.
25StarWhiteLightning
Midwest
2025 Star White Lightning Lariat
Hey everyone,
Makes sense. What is special about this coupler? Is it just a tried and true USBC coupler? I got the dock with integrated but curious if getting spare makes sense.
Can they be ordered from another source once you stop selling?
EVO
Randy
Leavenworth, Kansas
electrician
Without the coupler. the lightning will throw errors every time you start.
UncleTony
Tony
It is designed specifically to resolve can bus errors on the lightnings. I don’t believe there are other options out there at the moment. If you want a spare for the dock, I’m sure we could ship you a bare one that will drop in as a replacement if you let me know when you place the order (through DM here or discord).
I won't say we will never order them again if enough need arises, but I also wouldn't expect it.
Free Charging
Atlanta, GA
Tesla Model Y
Obviously support people supporting the project first, but in the future or as a stop-gap, would something like this with a 360-ohm resistor across pins A10 and A11 functionally serve the same purpose, albeit with clumsy packaging and probably less reliability?
UncleTony
Tony
Yeah, it would still functionally work. But I’d advise against it since they’ve been known to break/fail since they aren’t intended for long term use and you have the risk of shorting out the connections if you’re not careful.
UncleTony
Tony
Chestnut improving long control?
Coming from someone that is familiar with the rivian community, some are good at creating hype over things that really don’t deserve it. I’d wait for additional reviews to come out.
BluesClues
2022 f150 lightning sr lariat
Comma CTO showing the difference in trajectories. This should translate (unless it hits torque limits)
