Rotary Shifter Part Numbers
mr.Magoo
2022 Lariat ER, AMB
https://www.f150lightningforum.com/...inted-rotary-shifter-holder.25541/post-503066
me_myself_and_I said:
In the name of science I can report that the Maverick NZ6P-7P155-AD, Escape PZ1P-7P155-HC and E-Transit NK4Z-7P155-D shifters work (for me, no guarantees or responsibility how it works for you) and appears to retain all functionality including Auto Hold.
The Escape dial has ambient light in the base of the dial, Maverick and E-Transit does not, neither of them have a mechanical / motorized return, it's just the LED indicator emulating that it's moving back.
UncleTony
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I wonder how hard it would be to figure how to reprogram these with forscan if they truly behave differently. I would think we could compare the asbuilt with the ones that don't behave as expected.
Unfortunately the GSM is one of those modules that cannot be accessed with FORScan. At least for configuration. Can only see version numbers. No programming. :(
UncleTony
UncleTony
Tony
I mean, honestly makes sense due to the safety aspect of it. I was about to go check after I got my daughter back down.
JimH05
2024 Lightning Flash
I have a -U on order that I should be able to install the 2nd week of August. Fingers crossed that it works at all, I will let you know whether it is motorized or not.
Mike G
N. AL, USA
Also, has anyone installed the bronco sport rotary shifter? I like the looks of that one better but don't see any part numbers for that in this thread. Is the shifter the same size as the other ones i.e. will the 3d printed parts fit either shifter?
I did. From a '21 model. It is motorized, and throws zero DTCs with all functionality proper and correct. Part# LX6P-7P155-LE. It may have not made the list yet. Oh, and I do use Auto-Hold and it works fine.
UncleTony
UncleTony
Tony
I used ChatGPT to format the list and I think it deleted some of them. I'm going to go back through here in a bit and see what's missing. So much for making it easier.
Robocop
Can you confirm whether it was motorized or not too? Assuming it's a yes but just want to be sure.
Hi,
mine is not motorized if I understand the classifications being used here. To be clear the dial spins past drive. If the truck is in gear and I open the door it shifts to park automatically electronically but the dial doesn’t physically move. The auto hold feature also works the same as with the prior shifter - normally. Also when the truck is in neutral and I press the “L” button, the Neutral light blinks. That is everything I’ve noticed with the mod so far.
UncleTony
UncleTony
Tony
We should be up to date now, Please let me know if I missed anything. I used my very own brain this time.
