ForScan HVB capacity number…should I be concerned?
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
Hello All Again!
I realize too much info can cause undue worry…but I was playing around with ForScan today and everything looked good on the PIDs, except for EV battery capacity. Shows “88”!
I’ve been getting poor range, but it’s winter in Illinois. Does this number mean my actual HVB capacity? Guessing it should be 98 (listed) or the whatever the real capacity is. Do I have bad modules or does this number mean something completely different?
Thanks everyone!
Ford F-150 Lightning ForScan HVB capacity number…should I be concerned? 27445639-0DA6-4370-AB54-CCF99EF1DAC0
MickeyAO
Mickey
San Antonio Tx
Lab Manager of the Energy Storage Technology Center
There are two different SOC readings. Displayed and actual.
jallen
Correct, those are shown in the photo as well. I understand those. I’m referring to the bottom one “ev battery CAPACITY.”
Danface
Dan
Central Mass
2023 Lightning XLT
I belive the values are hexidecimal so 88 would be (8*16)+8 = 136 which I believe is the real ER capacity
Newton
WA State
VW e-Golf, Lariat SR, Kia EV6, Toyota T-100
Forscan seems to have a few display bugs. I‘m pretty sure that your 12V battery is not charging at 147.00 volts. 14.7 is more sensible.
I assumed it was the useable capacity. I thought actual was over 140kWh?
mme_and_lightning
MME 2022 Iced White, 2023 Lightning Platinum
I have a Platinum. Suppose to be 300 mile range. I was planning a trip this weekend and put the truck to a 100% charge (first time) and the range was 328. The weather was 75+ and below 85.
I bet with cold weather the max range will be 275. Every EV owner learns their vehicle over time. Give it a year and understand range vs load, speed, how you drive, etc.
Be happy.
kstype
Kurt
Pennsylvania
Senior Systems Engineer
That’s great information on the Hex value.
Does anyone actually have a link to a document for these metrics in OBD? Even an SAE PDF or something would be great to have - I have found nothing in my searches.
