Frunk opened when using keypad door unlock
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
I went out to my garage to retrieve something from my 2024 Flash. Didn't have my key fob so I used the keypad on the driver's side door jam. BTW - I have found this keypad to be very useful. Almost didn't lease the truck cause I thought it would be useless. I use it a lot. - When truck unlocked the frunk lid opened up. I just had to push the interior button by the steering wheel to close it again.
Has anyone else had this happen to them?
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
The last number of your door code is the 7-8 button! You must have hit it an extra time because that will open the Frunk from the keypad if pressed within 5 seconds of entering your passcode.
jetfixr1
Anthony
Atlanta
Didnt know that!
Didnt know that!
Using the Keyless Entry Keypad
Unlocking the Driver Door
Enter the factory-set five-digit code or your personal code. You must press each number within five seconds of each other.
Note: All doors unlock if the two-stage unlocking feature is disabled. See Keyless Entry Settings.
Unlocking All Doors
Enter the factory-set five-digit code or your personal code, then press 3-4 within five seconds.
To Release the Frunk
Enter the factory-set five-digit code or your personal code, then press 7-8 within five seconds.
Locking the Doors
Press and hold 7·8 and 9·0 at the same time with the driver door closed.
Note: You do not need to enter the code first.
Manual references
Ford F-150 Lightning Frunk opened when using keypad door unlock 1740520504530-l8
