How do you know HVB cooling system is working?
3rdgenfan
Geoff
Delaware
Cybersecurity
I'm also concerned that the HVB cooling isn't working in my truck (22 ER Max Tow Lariat). I noticed strange charging behavior this weekend thanks to the charging curve graph displays at the new IONNA rechargeries. I plugged in my ODB bluetooth reader to check temps and things looked pretty toasty to me. I also snapped a picture of the IC after disconnecting the truck, and the battery temp gauge was almost to the top end of the "normal" region. I'm in the gulf south so ambient temperatures are beginning to hang out above 90F.
I noticed similar behavior (though not quite as extreme) last summer and had my local dealership investigate. They reported no faults, topped up the expansion reservoir, and said the truck was fine. If this is an actual problem (which I think it is), do you guys have any guidance on what to tell the dealer?
I've had 4 back to back DCFC sessions on a road trip around the same ambient temperature and the battery temps never got that high.
I see an entry called "HVB Coolant heater" and there's one for the cabin AC. The "heater" one always shows 0 kW, and "ACCC" shows 0 amps when I turn off cabin AC. Is there another one I'm missing that I should be monitoring?
When I got in the truck this morning, battery temps were ~92F after overnight AC charging. I noticed my Tesla wall connector flashing red and the charge rate was derated. Searching attributed this to temperature, but I wasn't clear on if that could be triggered by the vehicle. Anyway, I decided to put the truck in Sport mode to see if it would attempt to cool. Once I got moving down the road, the lowest I saw the inlet temp get to was ~78F. If I remember right, since I noticed the higher battery gauge last year, I've never seen the inlet below about ~75F unless ambient was at that temperature or lower. Ambient was in the low 80s this morning.
Does your truck have Max Tow?
If it does, then there is a second AC compressor dedicated exclusively to cooling the battery, while the cabin AC is exclusively for the cabin.
I don't know what the second AC PID is, possibly another member has this information.
Maxx
Maxx
Here are my current temp page sensors. I am going to replace the three with no readings. Any suggestions for sensors that may be relevant to this thread?
Ford F-150 Lightning How do you know HVB cooling system is working? MotoMotoTemps_20250518_140033
Louisiana
I brought my truck to the dealer last Friday to have this checked out, and I just got it back. They found a leak on "the low side port of the cabin cooling side" and both the cabin cooling and battery/motor systems needed to be evacuated and recharged. All 4 schrader valves were replaced and the system was checked for leaks. I haven't had a chance to test with a DCFC session myself, but I'm hoping the issue is resolved. I have to thank the forum for assistance here because I was able to reference the thread below to point the service department in the right direction.
https://www.f150lightningforum.com/...ing-derating-significantly-on-hot-days.20209/
mr.Magoo
2022 Lariat ER, AMB
Thanks for reminding me, I don't think I have added signals for this in my blackbox.
I can't find another PID for the second compressor current, however, there's a secondary control module, ACCMB. I'm not home / near my truck so I can't verify that they give different results, but
ACCM Module is 7C7 and ACCMB is 6E0, PID is 0x2299AB is someone wants to give it a shot.
