Mildew smell from A/C
DreamBrother1
Midwest
2023 F150 Lightning Pro, Subaru Ascent
I've had recurring mildew smell from the A/C the past couple years. I've tried some things. Lysol in the air intake. Frigi-Fresh in the air intake. Ozium in the intake. Kool-It kit foam sprayed into the drain to the evaporator a few times. New cabin air filters. I run the fan without A/C or recirculation for 5 minites at 75 degrees anytime I use the A/C to help dry out the system. These interventions help, but nothing lasts. Anyone with similar issues that tried anything else?
Have you tried an activated carbon air filter?
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
I get a mildew smell in my truck after it rains, I believe it is rainwater collecting in the sunroof drains, in particular the fabric wind deflector. In my case it's not the A/C. If I park in the rain I will smell mildew when I get in the truck before I even turn it on.
tubby
Press
Iowa
Do you see water dripping from the drain on a humid day with the A/C is running? If not, you may have a plugged drain tube...? Maybe you tested that out with the Kool-it kit foam.
DreamBrother1
Midwest
Thanks that's a good idea, I need to check on this again. I should also note for others, I have a Pro trim (no sunroof)
ktom
Kevin
Austin, TX
2023 F150 lightening, 2022 Tesla Model Y, 2014 Audi S5 6/spd
Self employed
This is the same for me. The ford people have replaced all the A/C components and cleaned the drains in the past to my complaints. The smell still occurs, after it rains.
Tom M
Bossier City, LA
2022 F-150 Lightning Lariat, 2025 VW ID.Buzz
Pilot, Instructor
BluesClues
2022 f150 lightning sr lariat
When replacing your filter, take Lysol spray and turn your AC on and blast it in for 30s.
I use the Bosch HEPA. Fixed this problem.
CrimsonGhost603
New Hampshire
2022 Ford Lightning Lariat ER - Black
Cybersecurity
I see you’ve mentioned spraying Kool-It. Have you created a service port behind your glovebox? This helped me significantly with controlling the smell.
Steps I used
Spray cleaner
  • Spray short bursts.
  • Try a few angles to coat more of the coil.
  • Let it sit
  • Wait 10–15 minutes.
  • Cabin filter still out.
First dry/run cycle
  • Start truck.
  • AC ON
  • Fan HIGH
  • Fresh air / recirc OFF
  • Run 10–15 minutes.
Final dry cycle
  • AC OFF
  • Fan HIGH
  • Fresh air still preferred.
  • Run 5–10 minutes.
Check drainage
  • Look under passenger/front area for water dripping.
  • Dripping is good; it means the drain is working.
Reinstall cabin filter
SERVICE PORT:
Ford F-150 Lightning Mildew smell from A/C IMG_2703
Ford F-150 Lightning Mildew smell from A/C IMG_2706
Ford F-150 Lightning Mildew smell from A/C IMG_2708
Ford F-150 Lightning Mildew smell from A/C IMG_2712
CrimsonGhost603
New Hampshire
Cybersecurity
As a side note: Simple Green AC coil cleaner is a much better product in my opinion, but the can needs an adapter. I finagled an aftermarket cap and drilled the end so it could use the wide spray nozzle from the Kool-It can. This only worked one time then it broke. The Lubergard Kool It can has a larger stem than the Simple Green coil cleaner can. If anyone can find a solution to this it would be great, as smaller nozzles do not work since the foaming action is required.
hoovertac
Brad
Tacoma Washington
AWD MME Extended Range
Crisis Counselor
Thanks for this post. I’ve recently started to notice a funky smell & keep the truck clean. Never made the connection that it could be the A/C. You seem to be doing more than I would recommend. If the smell has penetrated the carpet and upholstery an ionizer-machine session may be in order.
3rd rock
Automotive Technician
It did this on my last truck 2013 XLT, and it does it on this new one. I shoot Lysol under the dash where the fan intake is for recirc and up by the windshield where the fresh air intake is, fan on high, select your intake and blast half a can in there.
The smell eventually comes back so I chalk it up to just another maintenance item. I haven't tried the charcoal or hepa filter(s) yet so that's on the list, only have 3k on it.
