New GenerLink option (TN, and Utah)
BBL
TN
Lightning 2023 lariat er
I'm not sure how fast this is rolling out, but I got an email that goes to this link showing a GenerLink switch transfer in Tennessee and Utah according to the email. While I believe similar things have been around in other areas thought this would be useful for anyone looking at options. If it had been available two years ago I'd have likely gone this route.
https://shopgenerlink.com/pages/for...v-own_npr_ns_ns_tp1_1_nt&fcid=eml_E26A1339_sf
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
That is exactly the type of solution I would love.
I have a heat pump that I believe the truck could run just fine (with a soft start kit), but its on a 60amp breaker due to the auxiliary heat coils. I can disable the heat coils in the settings, but there is no clean way to move the 60 amp circuit to transfer sub panel without buying something much larger than I need or can use.
Powering the whole panel and just selecting my loads would be ideal!
GoodSam
Good
occupying space
California PG&E offers this "Backup Power Transfer Meter Program". "Quickly, easily, and safely power your home with a generator during an outage."
https://www.pge.com/en/outages-and-...rces/backup-power-transfer-meter-program.html
Shows a list of compatible generators, with:
-Ford Pro Power Onboard (PPO) F-150 Hybrid PPO 7.2 Kw
-Ford Pro Power Onboard (PPO) F-150 EV PPO 7.2 Kw
-Chevrolet Power Base 240v 30A Silverado EV
As the first link notes, your utility governs whether you can install this or not.
Our utility, DTE, offers it at a monthly cost of a mere $22.99 a month. You cannot buy it, this is your only option. Only $99.99 to install. And, provides
  • Surge protection for your home with warranty coverage up to $5,000 per event for appliances and $1,000 per event to repair or replace electronics if damaged by a surge.
Such a deal. So many in SE Michigan despise DTE.
Firebelly
Lawrence
2022 F150 Lightning Lariat
I had one of these decades ago, and it worked great. I just had a shitty pull start generator, but it was enough to run the 240V furnace fan to keep the whole house warm in the winter. Plus, every single light switch and socket is live, which is super nice. Just don't turn on the AC or the oven and you'll be good.
$250 - $400 installation cost is fantastic.
I saw something interesting….an electrician installed a second meter can on the premises side of the utility meter and mounted the Generlink on it. The utility has no say in what you can do on your side of the demarcation point. He cleared it with his local inspector first.
El Duderino
2025 Flash Job 1
I like this idea. I am surprised the inspector approved it.
Edit: the first post's link does say you can install it 2 ways and then shows a picture of the product after or behind the meter.
Ford F-150 Lightning New GenerLink option (TN, and Utah) Screenshot_20260327-154850
More info:
Ford F-150 Lightning New GenerLink option (TN, and Utah) Screenshot_20260327-155234
Timeless Epoch
Chad
They also list that as a valid installation option in their documentation. 👍
Ford F-150 Lightning New GenerLink option (TN, and Utah) IMG_8934
El Duderino
2025 Flash Job 1
Regarding the neutral and ground bond, I assume this transfer switch also switches the neutral if they are advertising compatibility with Ford ProPower.
Does anyone know if these Generlink's are neutral switching?
daczone
2024 Lightning Lariat
Seems expensive for a Generator Hookup. And it won't power your entire house. You'll have to switch circuits off to not overload it. I used this system before I went Solar: Cheap, Easy to install and Works great:
Ford F-150 Lightning New GenerLink option (TN, and Utah) 1774704183041-ta
Pick your 6 most vital circuits and they are wired to this new panel.
This is new. When this was first discovered on the forums, I contacted Generlink directly, and was told I had to go through my utility. So, now the question is - what does it cost to have an electrician put a meter box in and switch the feed over?
Firebelly
Lawrence
This is a totally different solution. The great thing about generlink is it has the ability to energize EVERY circuit, not just 6. In my case, all I had to turn off was the AC and oven. EVERYTHING else worked - every light, every outlet, every TV, etc.
Also, for a utility approved installation, the installation is a lot cheaper, since all they have to do is unplug the meter, plug in the generlink, and then plug the meter into that. No rewiring!
