Not charging
awilli1010
SE Michigan
My lightning won’t charge. I’ve tried 3 different chargers so that’s not the issue. My current charge is 80%. I normally charge to 90%. I deleted ford pass and reinstalled. That didnt help. In fact, I lost my saved and previous charge locations. Even without those it should still charge when plugged in. Any advice before I call the dealer? Tia
HaroldCal
Harold
Las Vegas, NV
Does it indicate that it's plugged in? Do you hear clicking?
awilli1010
awilli1010
SE Michigan
It says plugged in, not charging. Not hearing the normal clicks that are heard when charging starts.
HaroldCal
Harold
Las Vegas, NV
Do you get any errors/alerts in Ford Pass??
Ken
Ken
Monterey
Lightning Lariat ER
Is your charge ring turning red/orange when you plug it in? If there's a DC fast charging location somewhere in your area go try that and see if it works. My internal charging system died, and it would not charge via AC, but only DC. Dealer changed out the charging port and internal AC-DC converter under warranty.
HaroldCal
Harold
Las Vegas, NV
Yep, same here. That's where I was leading to.
awilli1010
awilli1010
SE Michigan
I don’t have any errors or alerts in ford pass. The charge ring is blue when initially plugged in and then goes out. Never seen any red/orange. I have a dcfc about 20 miles away. I will try that today. I also have the 23H01 recall scheduled for 4/24. Ford can maybe fix it then. Thanks for the information!
What is the max charge level set in the truck?
Delete all charge locations via the Sync screen in the truck.
awilli1010
awilli1010
SE Michigan
I just went to leave and decided to try charging one more time. It worked, I don’t know what the issue was. I added my home location to ford pass and now everyone seems okay. Keeping my eyes on it and crossing my fingers! Thanks everyone for your help. This forum is awesome.
Add your locations and charge times in the truck, not the app. The app is not to be trusted.
Ford Motor Company
Official Ford Account
Ford
F-150
Hi there, I'd be happy to look into your Lightning concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
