Park Brake Failure - Service Immediately: fix #9
Crash McBang
Crash
2022 f150 lightning
Avoider Of Yard Work
22 F150 Lightning, SR Lariat.
Anybody get this message on their dash? Went away almost as fast as it appeared. No odd noises or other indication.
chriserx
Louisiana
May have been slower to activate than it liked, since it showed that message, it likely saved an OBD code you can reference to get more info on what went wrong.
Try testing the parking brake to see if it's actually working or not.
In a safe level place, put the truck in neutral, using the 30 minute lockout timer.
Manually activate the parking brake.
Open the door, and see if the truck is held fast from rolling forward of backward, a helper might make the test easier.
If the warnings persist and parking brake is not doing its job, I'd get the truck into service ASAP.
MountainAlive
Massachusetts, USA
Were you parked on an incline? Parking brake is supposed to automatically engage at certain degrees of incline (not sure what the threshold is). Maybe it detected the incline but the brake didn’t engage?
Crash McBang
Crash
2022 f150 lightning
Sorry, I forgot to mention that I was going about 30MPH downhill when the diagnostic appeared. There was also a fast bing-bing-bing sound, then the diag went away. I will do an OBD dump tomorrow and report.
Crash McBang
Crash
2022 f150 lightning
From BlueDriver:
Odometer: 16,825.984 miles
1 Engine Control Module
874496 No description available
0 Confirmed Codes
0 Pending Codes
chriserx
Louisiana
I've never seen an error code in that format. Usually start with a letter AFAIK
Crash McBang
Crash
2022 f150 lightning
Service scheduled for end of January(!), will post resolution then, if any :cool:
Crash McBang
Crash
2022 f150 lightning
Resolution:
C/S: PARK BRAKE FAILURE SVC SOON APPEARED ON DASH WHILE GOIN
G DOWNHILL AT ABT 30MPH. ECM CODE 874496
UNABLE TO DUPLICATE COMPLAINT-PERFORMED SELF TEST,C0609-CD
OASIS,NO MESSAGES-PERFORMED PPT A1,ACCESSED C2015 AND
DISCONNECTED,PERFORMED PARK BRAKE SWITCH COMPONENT TEST IN
APPLIED POSITION/.8 OHMS-A2,PERFORMED COMPONENT TEST IN
RELEASED POSITION-FOUND INTERMITTENT CONTINUITY IN REST
POSITION WHEN RELEASING FROM PARK BRAKE RELEASE
POSITION-REPLACED PARK BRAKE SWITCH-CLEARED CODE AND
RETESTED,PASS-PERFORMED PARK BRAKE INITIALIZATION-PAR BRAKE
OPERATING NORMAL-AD TO PERFORM COMPONENT TEST-CASUAL PART
#2B623
Looks like a flaky switch was replaced. $100 charge.
