You and the rest of us will have to wait for deployment of a proper OTA, what you got was a dud....I received the update but can’t find the option on my screen. Where do you find it please.
Foreskin?I would start dusting off your FORScan cable.![]()
If you need to knock the dust off of that, you got a whole different set of problems.Foreskin?
I was hoping wireless app projection was improved with this update. I'm so used to just using a wired connection at this point, I will probably just continue to do so whenever Ford deems me worthy of getting it, but happy to hear. I see SO many posts of people complaining about this on every Ford forum in existence.wow, since the update I have not had one wireless CarPlay failure. even if its not perfect this is better than ever before.
So even though you don't have the OTA push, you are saying you also still don't have an APIM queued?I was hoping wireless app projection was improved with this update. I'm so used to just using a wired connection at this point, I will probably just continue to do so whenever Ford deems me worthy of getting it, but happy to hear. I see SO many posts of people complaining about this on every Ford forum in existence.
No as of two days ago when I plugged into FDRS.So even though you don't have the OTA push, you are saying you also still don't have an APIM queued?
None of the frunk buttons would work (cab, frunk hood, FordPass). The frunk closing beep wouldn’t even sound if any of those buttons were pressed.@Jim Lewis I noticed after this update that this was added to the access menu where I can now tap the screen and electronically just pop the frunk. It doesn't power lift open. Is this what you are referring to?
I just hit the frunk button in the cab twice to make it close and latch.
