Phil D
phil
Law Enforcement
First “long trip” in the Flash. Lincoln Ca to Monterey Bay Ca. Navigation said I would make it there with 14% to spare, but stopped in Gilroy at Tesla Supercharger just to top off and stretch.
Screen said charging at 180-185 kw. I thought Lightning could only charge at 150 kw or less.
I figure 180 kw is what is available if I was driving a Tesla and, regardless of what the screen says, the Lightning is only pulling 150 kw.
Had to wait 2-3 minutes for a spot that didn’t block two chargers. I pulled right up to charger and slightly onto the curb (truck life ?) to get the charging cable to reach.
Surrounded by Teslas but no dirty looks that I noticed.
Averaging 2.1 mi/kWh with average speeds ranging from 65-80 mph. Mostly 75 mph. Outside temperature of 65-70 degrees. Interior temperature set 71.
Super comfortable and plenty of available squirt when I had to accelerate past traffic.
Tried Blue Cruise, but I prefer to do the driving.
Ford F-150 Lightning Sacramento to Monterey Bay, L3 charge at 180+ kw IMG_9795
Ford F-150 Lightning Sacramento to Monterey Bay, L3 charge at 180+ kw IMG_9796
The Weatherman
South Central KY
The Lightnings will hit 170-180kw for short period (10mins.) and the battery is at at a lower state of charge, if available and the temperature gods are smiling down on you.
electricpig
Tim
Northwest Arkansas
23 F150 Lightning XLT, Tesla Y
Some believe Ford has tweaked the charging curve since introducing the truck, but doesn't not change the official specs. Seems reasonable to not change the official specs so as to reduce the number of complaints.
broncoaz
Cape Cod, MA
I tested mine in the cold the other day, topped out at 124 kW. The battery wasn’t warm from sitting on a 29 degree day.
scruvs
I’ve definitely hit 175 or so for brief moments on some EA 350kw chargers on trips. Warm weather and sweet spot in the curve.
Early on I would try to be courteous and grab 150kw EA chargers and save 350kw chargers for those 400kw Hyundais and Kias, but the 150kw seemed to be a good 20% slower, so I started grabbing the fastest charger I could get.
Now I just go to Tesla because it’s so much easier.
astrand1
Alex
Studio truck driver
The Lightning team really needs to get us that have 22-23’s the ipc update like the 24’s have that shows actual charging amount on the ipc. I’ve heard that it’s coming but I would think that’s a fairly simple update. The info is there in the truck just need to display it.
Caliber357x
‘23 Lightning Platinum
I did a trip to Indiana over Christmas and in 15-30F weather was hitting 170s each time in the beginning, then it moderated down into the 150s. Only saw these rates at Tesla chargers though.
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
My 2023 Pro SR regularly pulls 170+ on EA Hyperchargers and Tesla Superchargers. It doesn't last for long - maybe 10 minutes - and the truck needs to be preconditioned and at 10% to 50% SOC. For context: I just hit 150 Electrify America DCFC billed charging sessions in eight different states (and some countless number of failed sessions), and probably another 100+ on a combination of Tesla, ChargePoint, EVgo, Francis, Circle K, Walmart, misc chargers. Yeah, I do a lot of long distance - 1500+ mile - trips; Lincoln to Monterey Bay is a neighborhood drive for me.
scruvs
Ralph, with all that DC charging do you wish you had an ER battery? I wonder because I have an SR and often think having an ER would make life easier on trips.
But, now I’m planning to wait to buy my next EV when ranges are 500+ miles and 400kwh charging and NACS port.
Ralph
Ralph, with all that DC charging do you wish you had an ER battery? I wonder because I have an SR and often think having an ER would make life easier.
I’m 70 years old - range for me is more about my bladder than the battery. I’ve developed an efficient routine at my combined rest/charging stops. And with access to Tesla and other chargers, I have plenty of flexibility on my primary routes. So, no - I don’t lust for the ER battery and I’m long past range anxiety.
