2021+ is Gen 14.Ok - I am really curious on how your are counting F150 generations. As far as I know, we are currently in the 14th generation....
This class of truck doesn't need a discrete frame. How many people pull their 150's bed off for an alternative? Zero. I'll take a stronger package vs wasted mass. Body on frame is a result of incompetent engineering, not unicorn design. The cybertruck isn't in the 150's class because it was designed right. Ford is going to have to respond appropriately, or continue to stumble. The EV packaging requirements are completely different than ICE, as are the body requirements. Cab on frame was a crutch for all sorts of poor design choices from engine to chassis dynamics.I don't see how that combination will sell to serious truck users for a long while.
It doesn't matter what you think is better, it matters what's going to sell and be serviceable and cost effective.doesn't need a discrete frame.
I was using the AutoList list of F-150 generations. My understanding is that we're in the 1st generation of the F-150 Lightning, the 9th generation of F-150 trucks, and the 14th generation of F-series trucks.Ok - I am really curious on how your are counting F150 generations. As far as I know, we are currently in the 14th generation....
As with a lot of mechanical engineering, body-on-frame versus unibody is a study in tradeoffs. There isn't a single universal answer that is better for all use cases: lighter, stronger, and easier to manufacture. So if you're going to call body-on-frame designs "incompetent", you've insulted a lot of engineers at Ford, GM, Ram, Jeep, Toyota, and Nissan.This class of truck doesn't need a discrete frame. [...] I'll take a stronger package vs wasted mass. Body on frame is a result of incompetent engineering, not unicorn design.
It's not a matter of opinion. That's like saying it's opinion that transmission fluid and engine oil are different products entirely. For less mass, a unified structure of significantly higher strength can be had. Easily 3-4x the torsional strength. I'm not talking a ridgeline competitor, I'm talking strength that exceeds that of a 250. Given the advantages that castings provide, quality would go through the roof. Factory floorspace requirements drop into fractions, as does the manpower required. That's the minimum it's going to take to remain competitive.The cyberbucket hasn't had any actual specs attached to it yet so no comparison of capabilities can be made, we'll see.
Battery packs need to be serviceable too and I really like the modular design.
I think it's because there is an irrational preference for body on frame among truck owners.there must be a reason why no other half ton has gone that route yet.
This. According to people who've seen it, it's very futuristic, but in a good way. Not like the upcoming electric explorer which apparently looks like a funky mash up of the mid 2000s Prius and model x. Cab forward design, looks like a late 90s/early 2000s f-150 redesigned for the year 2050, very radical looking, but again, in a good way.If they're smart about it, it won't share the F150's body, though will be inspired by it / share design cues. Shrink the frontal area putting it into bed length instead. 6.5' bed.
Dish out some dirt on that I guess. Guessing the next gen f-150 will be some small changes and improvements, nothing crazy. The same engine lineup with some hybrid assist added to things like the 5.0. Am I close?From the little information I know, there are current Lightning trucks fitted with the prototype next-gen drivetrains driving around. You probably won't see a full production ready prototype driving around until next year.
It was easy to make an early production Lightning and that it why you saw it so early. All they had to do was build a truck, take the ICE drivetrain out and install the electric drivetrain. The new truck is totally different.
I don't have a lot of information on the new Lightning because the engineers I get my information from aren't working on it. They are working on the next gen ICE truck. I have some good dirt on that.
Don't know about engines, but I'm hearing it will be a ground-up redesign. Sounds like the Supercab will be axed too.Dish out some dirt on that I guess. Guessing the next gen f-150 will be some small changes and improvements, nothing crazy. The same engine lineup with some hybrid assist added to things like the 5.0. Am I close?
It is way past time to scrap the Supercab. I know there are followers that like that, but not enough to make it worth it. We still don't know how well the Cybertruck will do, but we know major costs in assembly are all the different options and variations, Ford has millions of combinations, Tesla will offer a handful, just like on the Model 3 and Y. The bread and butter of the F150 is the Supercrew. Ford screws that models bottom line to subsidize the others. You've got to get rid of the low performing models, just like small sedans of the last few years, they are gone.Don't know about engines, but I'm hearing it will be a ground-up redesign. Sounds like the Supercab will be axed too.
