Whistle on drivers door at highway speed
dothedew
Colorado
Anyone have this issue? I loathe going to the dealer... would like to fix myself.
it's a common issue, I have not had it addressed yet, not sure what they will/can do, but maybe a thicker body seal for the doors might fill the air gap
Skidrowe
Gideon
2022 F-150 Lightning ER, 2014 Honda Pilot
I can hear air/wind noise at high speeds outside the driver-side door on my truck. I'm not terribly thrilled about it, but I'm not sure if it's fixable or just how the truck was built.
SmoothJ
New Jersey
2022 F150 Lightning
I don't have a whistle per say but I just notice more air movement when I picked up the truck in July 2022. To help mitigate this, I checked all the rubber around the driver and passenger side areas (front and back). To my surprise, I found some of the plastic pegs used to hold the rubber seals to the door were not pushed in all the way. I also made sure it was a clean surface.
I also noticed that some of the windows did not seal all the way up from the factory. So I then did the window reset proceedure to make sure they are up all the way which helped correct that issue. I also opened and closed the sunroof too.
Ford Motor Company
Official Ford Account
Ford
F-150
Hi Gideon! I can look into your Lightning's noise concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Lightning's VIN?
TerryNelsen
Terry
Ca
F150
I had the same issue, went to the dealer and the service tech grabbed the top of the door and pushed in on it while another tech held the door , no more noise.
Ford Motor Company
Ford
F-150
Hi there, I'd be happy to look into your Lightning concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
idahospud
Idaho
2022 F150 Lighting, Indian Roadmaster
Commercial Real Estate
I had a plastic trim piece on the door molding slide down about an inch - this caused some whistling. I slid it back up and added a section of black electrical tape to hold it in place - problem solved for 12+ months now.
