Would this be a warranty item worth fixing?
Maineiac12
Iowa
I know this stitching should be straight. How much of the dash needs to come apart to fix this? Trying to see if it’s worth mentioning at my 20k service.
Ford F-150 Lightning Would this be a warranty item worth fixing? IMG_7187
The Weatherman
South Central KY
Not for me. If they would consider fixing it it will require replacing the upper dash board. Not likely they would ever get it back together to suit.
If you don’t tell no one will ever see that as an issue.
But hey, you gotta do you.
PJnc284
Garner, NC
This is the main thing keeping me from having them tear mine apart to see what the heck is sliding back and forth. Only hear it on a sharp turn or when having to brake quickly. Devil you know is sometimes better than the one you don't.
rdr854
Northern Virginia
Check the tray in your center console. It slides back and forth on turns as designed - or so afford dealer told me. Terrible design for a premium priced vehicle.
PJnc284
Garner, NC
It's definitely in the dash. Seen others report similar noises and ended up being a stray bolt or nut. Have something else sliding around in the bottom or my front passenger door that you can hear shift if you move the door real fast. May look into that one on my own if I get motivated enough. Guess they were losing stuff or forgetting Loctite that day.
Dan C
I used a couple paper clips to hold the tray still, it was driving me nuts on a winding road
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Platinum
Fix one problem for the dealer to create 10 other that bother you more
Lytning
Georgia
As an Engineer, I appreciate your extraordinary attention to detail.
Did you notice the dust on the IR emitter cover? 😂
CD4TNF
I had my moonroof window seal replaced under warranty. The tech had to dig into the grab handle cover to get at the roof and made a nick in the grab handle cover. I'm still staring at the nicked grab handle cover.
Repairs are not always risk free to a nice interior. Evidence of the work was left behind in my case and makes me notice the imperfection.
PJnc284
Garner, NC
Probably was in a hurry and not paying attention. It takes almost no force to pop that cover up to get to the bolts holding it to the a-pillar so you're not doing something right if you break or scratch it.
Maineiac12
Iowa
Yes! but I live on a gravel road so dust gets on everything 😆
Ford will likely say it is fine.
rdr854
Northern Virginia
It’s par for the course. My 2022 Lariat is very similar.
Pacific.NW
Christian
2022 Lightning Lariat ER
I have CDO (it's like OCD, but in the right order), and while that may bug me, I would feel the effort in trying to get it resolved would outweigh the aggravation of not having two parallel stitch lines. ;)
