cowboys1870
Alex
Oklahoma
‘22 Lightning SR XLT
My brand new Toyo AT3 EV 33” tires only used 3-5% more energy than 32” OEM Michelins.
Roughly 2.01 mi/kWh vs 1.95 mi/kWh
I drove the same 39 mile loop at 70mph with the HVAC set to 75° and speed set by GPS app.
Before and after each test, I charged to 70% displayed on the same Supercharger to help me gauge consumption. I started and ended at the same spot, with the same starting SoC. 94°F out, some wind.
I did the OEM Michelin 275/65R18 with 49k mi on them first, then the new today Toyo AT3 EV P275/70R18.
Also, my last 2,000+ miles on the OEM 32” Michelins averaged 2.3mi/kWh. The last 140 miles in the new Toyo 33”s also averaged 2.3mi/kWh.
I am very pleased with these numbers, and expect the Toyos will notice a bit as they wear in.
Join us on X, Facebook, or Instagram if you are in Oklahoma and interested in a Lightning meetup!
https://www.facebook.com/share/g/1CK7KJ23aK/?mibextid=wwXIfr
https://x.com/lightningokla?s=21&t=EJZWc2YBWXR2jGEG12D7CQ
https://www.instagram.com/lightningokla?igsh=d2t5aTMyOGswNnYz&utm_source=qr
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3258
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” image001
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3273
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3257
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3277
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3286
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3262
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3269
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3249
Ford F-150 Lightning Toyo AT3 EV 33” Tires Only a ~3% Range Hit vs OEM 32” IMG_3250
cowboys1870
Alex
Oklahoma
Ride quality?
Noise?
Thanks for the testing and report. Good to know we can get get AT tires without sacrifice range.
I would say the ride is about the same, perhaps a touch stiffer. These are the P rated 116T load rating, so not the stiff LT.
For sure more tire noise at 50mph on smooth roads, but wind noise takes over at 70+ mph and makes the tire noise unnoticeable.
CD4TNF
Neat thanks! Sounds like Toyo did a great job.
Madtroniks
Diamond Sponsor
Ford
Thanks for the detailed write-up. I run the Toyo AT3 EV in 34" on my Rivian and I also did not notice too much change in efficiency.
Mal106
Mal
SW VA
2025 Lightning Flash
Retired Pilot
Did you have to do any compensation for tire diameter?
