JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Is there a confirmed way to get the cloud AsBuilt days updated properly without one of the more expensive adapters? I have spaces and garbage data in the XML download from Motorcraft and I'd like to fix it if I can.
No, not on demand. You will need to wait until the truck self-reports its data. Time frame for that is unknown. Mine never self-reported. I had corrupted data for at least a couple of weeks before I decided to spring for the Mongoose. Others reported at least a partial correction within a few days. Unfortunately, nobody has figured out a way to trigger a self-report. @iceman77 wrote that he tried but was unable to do so.
Thekameleon
Chicago
2021 Ford F150
I was there, for a very long time and then randomly one day it kicked over and I got past 1.7.1. That's gotta be the hardest part, once you get updated to 2.1 you'll probably be able to update easily from there on out. I'm stuck getting to 2.3, my usb start consistently but I get stuck in "restart truck to finish" loop.
Just curious, how long?
jmm3807
Phoenix AZ
www.seasavvyaquarium.com
2021 F-150 Platinum 4x4
Business Owner
Wanted to ask some advice. I got the VX nano and have been updating modules tonight. Well everything went ok except when it came time for the Side obstacle detection control module c, d, LH, RH. When trying to update each one they all appeared to fail. Fast forward and now when using the truck I get Blind Spot Detection w/cross traffic off warning. Any ideas on what I should try next? VIN: 1FTFW1E8XMFA27075
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Just about a month, and that was with trying everything the smart people on this thread threw at me. Literally randomly while sitting at Sonic it kicked off out of the blue.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Maybe I should add to the doc? :ROFLMAO: Mine came the following morning.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Are the updates still in your list? If so, retry the updates. If not, I would probably try to PMI the module(s) and see if that resolves it. Maybe someone else has better insight though.
apMechorse
Steve
Fargo, North Dakota
'21 Ford Lariat 5.0L FX4; '14 Chevy Spark LS
Aircraft Maintenance Manager
I guess I'm having Sonic for lunch today then, because at this point I'll try just about anything to get this ^%**&% APIM update to trigger.
JEB
Northern Illinois
I’m not sure if this has been mentioned before, but with the Ukrainian war, it’s possible we could lose access to FORScan. Although the developer appears to still be releasing the 2-month trial licenses, at least for now, it has stopped selling extended licenses. One of the nice things about FORScan is the ability to reload as-built data. Fortunately, there is also a tool in FDRS that will allow you to reload your as-built configuration should you need to do so. Page 3 of the attached Global FDRS Quick Reference Guide (old, but still somewhat helpful) confirms that the “[Module Name] Configuration” tool is the FDRS version of IDS’s as-built tool. https://www.fordservicecontent.com/Ford_Content/Catalog/ids_manuals/GFDRSQRG1p2.pdf
JScaro
Georgia
2021 Ford F150 Lariat
Beer Drinker
Check under your Features / Driver Assistance options, it may be off. When I did the TRM it turned off some of the features and took me a few days to figure it out.
Ford F-150 Lightning ECU module programming guide using FDRS 28CE0C7E-5BCC-4ECC-80E8-094CACA930EC
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Interesting. Looks like Ford’s answer to FORScan Lite. Might be good for diagnostics but it doesn’t appear to support programming.
It’s not coming up in the App Store for iOS Yet. But it does require a subscription. They better be offering something for the subscription.
JEB
Northern Illinois
Probably because they’re not shipping the device yet. It will cost $499 when released on or about 3/22/22 plus the $149.99 cost of a 1-yr subscription. At that price point I’m having difficulty seeing the value since it doesn’t appear to be a programmer.
