JEB
Northern Illinois
2021 F-150 Lariat Powerboost
The charger wasnt the problem. The long hold down bolt was a weak ground spot for me. My battery was recently changed at the dealership and when they changed it they apparently put anti seaze on the threads which was causing me to get a weak ground. Thanks to @Bob_Mac he figured it out and Now Im back to 12.6 volts. Scary for a minute
Anti-seize is non-conductive. So, that post is useless as a ground now. Finding a good ground in these trucks is a pain in the ass. Plastic everywhere. Sounds like @Bob_Mac saved your kiester.
JScaro
Georgia
2021 Ford F150 Lariat
Beer Drinker
Best way to connect the charger I found. That long hold down bolt SUCKS. I tried it and got blistering hot - bad ground.
Ford F-150 Lightning ECU module programming guide using FDRS E52D403E-5DFD-40B9-8159-E89C583CFA7C
iceman77
Pete
2022 Ford F-150 Platinum
I’m going to”steal” your picture and add it to the guide in the beginning of this thread :)
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Is there anything special amount of time I need to wait once it tells me to turn the Ignition off for the IPMA module software update
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
My ignition is off and doors open
20ecoboost21
South Carolina
2021 F150 tremor
I'm using the VX Nano tried updating the CCM and now it's purple. Is there anyway to recover it using the Nano? I have a mongoose cable ordered just in case.
JEB
Northern Illinois
If you want to be certain, shut your doors and walk away and leave the fob out of range. Return in about 10 minutes without the fob and look through the window at the LED halo around the rear seat USB ports. If it’s out, the truck is as dead as it will ever get. If not, wait longer.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
You have joined an exclusive club of CCM owners. I might be the founding member, but I can't prove it. I too am about 48 hours from delegating a CCM rescue attempt to the Mongoose. Hope it goes well for us.
Jesse-Infotainment
2024 F150 Lightning Platinum
I think the nano is the issue on these modules. These modules are on a canbus the ipma creates.
The modules that were purple were fixed simply running the software update at the dealer. Nothing more than that . That tells me it’s a comm issue
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
@Jesse-Infotainment @iceman77 we have an issue. My updates were fine when installing and now I am having issues as others have indicated. Taking a drive bought it to my attention when I saw "Pre-Collision Assist Not Available". I'm getting the extra 'ML3T after whitespace and a persistent DTC U2101 and using the Mongoose, see below:
Ford F-150 Lightning ECU module programming guide using FDRS 20220313_170955
Ford F-150 Lightning ECU module programming guide using FDRS 20220313_172608
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Okay so
I was just going to ask you if this is normal with the purple CCM module. I thought everything went well with my ipma update
Bob_Mac
Bob
North Carolina
This wasn't looking like this earlier as I d/l my AsBuilt before and after and now:
Now:
<NODEID>
706
<F10A>ML3T-14H106-AFN</F10A>
<F110>DSML3T-14G647-AL</F110>
<F111>ML3T-14H107-FF</F111>
<F113>ML3T-14G647-NA</F113>
<F120>ML3T-14H102-MDM</F120>
<F121>NL1T-14H102-SBD</F121>
<F122>ML3T-14H102-GAP</F122>
<F124>ML3T-14H103-AAJ</F124>
<F125>ML3T-14H103-ABP</F125>
<F127>ML3T-14H103-GAM</F127>
<F129>ML3T-19G490-BB ML3T</F129>
<F12A>ML3T-19G490-BB ML3T</F12A>
<F12B>ML3T-19J220-AB ML3T</F12B>
<F12C>ML3T-19J220-AB</F12C>
<F12E>ML3T-19G490-CA</F12E>
<F16B>ML3T-14H310-BDR</F16B>
<F17F>1AA14WB4</F17F>
<F188>ML3T-14H102-ABS</F188>
<F18C>ECUR2107300491</F18C>
<F1DC>ML3T-14H103-GBF</F1DC>
<F1E0>PXML3T-14G647-AA</F1E0>
<F1F3>28741964</F1F3>
</NODEID>
After update this morning:
<NODEID>
706
<F110>DSML3T-14G647-AF</F110>
<F129>ML3T-19G490-BB</F129>
<F12A>ML3T-19G490-BB</F12A>
<F12B>ML3T-19J220-AB</F12B>
</NODEID>
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
My battery was never changed and/or removed. That bolt is just not a good ground. So don't feel bad.
Jesse-Infotainment
Check your as built. The as built should change. Show me just the top line of the ipma
