TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Relllk&5
Mine is ML3T-14C026-BAK also for IPC
8” cluster as well
Ajzride
Alan
Houston
Eng
I'm an XLT with non-bluecruise and non-360. I'm stuck at 244 and have been for at least a month (after doing my initial updates via the nano.). I got my mongoose over a week ago, applied a few updates, but have not been presented with any additional updates to move beyond 244. My VIN is 1FTFW1E86MKD74376.
Someone in a different post mentioned their IPC has a F120 line in addition to F188. I've only got F188 so I'm wondering if my IPC has some sort of issue that's preventing me from getting any further updates.
Are you looking in FDRS or in the widget. Sometimes in FDRS the F120 shows up in the chart, and F188 shows in the data below it when you click on the module.
TJSparky
WA
Relllk&5-
What version is your sync at?
TJSparky
WA
Sync4 v4.0.21281
ok I think you and I are in the same boat. Same model and trim levels. I think the higher trim models are getting more updates for Sync than we are.
RellIk&5
Wayne
Las Vegas, NV
2021 F150 XLT Black Widow
Hopefully that's the case. I feel a bit better knowing I'm not the only one with this configuration of truck that's not getting further updates.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
So @Jesse-Infotainment, what do you think? Should I start my next round of updates?
I do have the mongoose so all should go well there. I'm cheap too so I only do the 2-day license but dedicate all my time to it.
Also, was there ever a conclusion on whether FORSkin updates affected the outcome of FDRS updates, especially in the IPC?
FORSkin? lmao. Some people were affected by FORScan changes in the IPC, IPMA and APIM and it is advised to revert back to allow for a smoother update and to avoid configuration mismatches. The choice is yours...
TJSparky
WA
I just looked in FDRS and our truck software part numbers are identical except for PCM but that maybe due to us having different engines. I have a 5.0L
20ecoboost21
South Carolina
2021 F150 tremor
What are your part numbers either in FDRS or from the widget?
My GWM number is ML3T-14H021-EAJ Also my sync version is at 21223 REV 197
My vin is 1FTEW1E86MFC76534 if someone can check to see if it shows any other update other than the GWM because that's all it's showing on my side.
Jesse-Infotainment
2024 F150 Lightning Platinum
I’ll have to look at the 8” cluster to see what the most up to date versions are. That could be the same as what ajz was having the cluster didn’t show up to date preventing the next round of updates.
Ajzride
Alan
Houston
Eng
Still just a gateway.
christophers
Christopher
Austin, TX
2021 F150 Platinum Hybrid
all i see is your GWM update as well. however, once updated, other updates will likely show up
20ecoboost21
South Carolina
2021 F150 tremor
Any tips on how to get past the GWM update. I go through the update process and even the USB update says complete on my radio screen but never clears on Fords side.
