Charge Station Pro Problems
FlasherZ
St. Louis Metro
Today my electrician completed the install of the Pro 80 amp charger while I was at work. When I came home, I attempted to "pair" to the unit unsuccessfully for about an hour. I stopped using the Ford Connected Charge Station app (as suggested with the inbox directions) and attempted to connect though the Ford Pass app - that process worked (unit went into pairing mode as evidenced by flashing "white" bar on front of unit and connected to wifi). Although the box is connected to wifi I have not successfully linked the unit to the the ford pass app yet (to many attempts - retry in 15 Minutes). Also, it is 103 degrees in in my town today, my garage is in the upper 90's. The unit has been charging for while with no overheat issues yet - fingers crossed!
You may be waiting a few days to connect it to FordPass. I had to do a complete factory reset because it still showed "ChargePoint not found!" in the app even after a day.
Someone else said it took a few days but then it worked.
I have found that with 80 degree ambient temp, the FCSP in my garage will work for 20-30 minutes before it starts cycling.
CTBob
Bob
Connecticut
2022 Lightning
We know some of our customers using the Charge Station Pro are getting error messages on FordPass while charging. We plan to push an over-the-air (OTA) update in the coming days to rectify the issue. To ensure this OTA update is successful, customers should ensure their Charge Station Pro is connected to their home WiFi.
Customers can continue to use their Charge Station Pro in the meantime. Thanks for flagging with us and for your patience while we get the OTA update out to your charger.
If the corrective action is going to be OTA, I will not be able to receive it if it comes through Ford Pass. Please see the picture of my charger sticker which only has an access code which does not work when I try to enter it into the charger network SWA32KCM. How do Get a password? THanks
FlasherZ
St. Louis Metro
The access code is also your password. You might want to delete that image, as someone can register your unit.
idahospud
Idaho
2022 F150 Lighting, Indian Roadmaster
Commercial Real Estate
FYi, The Access code is likley capitol i's not 1's.
Griddlez
Griddlez
Metro-East of St. Louis, MO
Highly recommend you delete that image when you get a second. Other folks could bind their ford pass to your unit like that (or god knows what else).
idahospud
Idaho
Ah yes, after an hour it started to overheat. I have reduced changing max to 64 amps until the issue is resolved.
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
Hi, you may have tried this, but sometimes fonts can be misleading. Won't be the first time this has happened! I'd try the following -
1) see DM
2) see DM
3) see DM
4) see DM
note: lower case L and upper case EYE look the same in many fonts so if they appear twice try all four combinations. Likewise for O and 0 which is less frequent but can happen.
I bet you (two Platinum active multi-contour seat w/max recline)one of these works!
Folks, exercise caution sharing network ID's and password/codes in public on the forum
Send a DM to a trusted subject matter expert on this thread, (I'm not one).
Who can take on that support duty?
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
I assume one can immediately change the password once they get in which is always a good idea. Just include upper, lower, number, and a symbol, and don't lose it ;). I'd be happy to assist anyone if question can't be posted if you DM. One of my many former hats was a network engineer, now I'd rather be sailing, or farkeling my 1300cc motorcycle or driving a full EV (someday?) when sailing weather is not good.
FlasherZ
St. Louis Metro
I recommend you edit the post to remove his passwords and DM your suggestions to him, since he posted his station ID above...
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
Sure thing, edited, and will DM him. Thanks!
FlasherZ
St. Louis Metro
I have not seen a way to change the station password, but I didn't dig too far.
Fast911
Tim
San Mateo,Ca
Silverado sold
I think you are right. I just found the difference between the upper case i, and 1….thanks! Will try next time I get a chance.
ChrisCon
The Hamptons, NY
Would be funny if @CTBob issue was I and 1 . I already explained O and 0 to him a few pages back .
Fast911
Tim
San Mateo,Ca
Silverado sold
Please give your best guess what letter this is? It is part of my access code and it’s not a number 1.
Ford F-150 Lightning Charge Station Pro Problems 3554974B-9967-4BE1-B356-A08DA02AD8C4
