Electrify America Pass+ vs FordPass Plug and Charge
RainorshinePNW
Anyone signed up for Electrify America's Pass+ (reduced rate per kWh for $4 per month fee) but also use Plug and Charge in FordPass?
dannynoone
Matt
Indiana
2021 Jeep Grand Cherokee Trailhawk
Big 3 Automaker Manager
Yes I’m using the free 250 from Ford through Ford Pass but have signed up for EA+. Used EA+ once before I had my Ford Plug and Charge setup.
GunRack
Peter
Seattle, WA
22' Lighting XLT
I have EA+ I used on multiple cars. Can I use Ford Pass on any EV though? I can't right? Wish it could just recognize my EA+ rate while Im there.
greenne
Nathan
Niskayuna, NY
I remember there was some info going around that although you can't link your EA+ acct(the one for $4/mth with a reduced rate) you could sign up for some special deal from Ford which was $50/yr. Basically it was $50/yr and you paid the reduced EA+ rate..but also got plug and charge.
I wouldn't wind paying what essentially is $2 extra per year($50 vs $48[12x$4]) for the added convenience of plug and charge.
Can anyone confirm?
RainorshinePNW
RainorshinePNW
Can anyone confirm?
Agreed. For the times each year I will be driving a long distance and need to recharge in quantity, that will be worth it.
GunRack
Peter
Seattle, WA
22' Lighting XLT
I agree but then I can't use Ford Pass with my other EVs right? So its really $50/yr just for the Ford and then $48 to EA for my other account I can charge my other EVs with.
greenne
Nathan
Niskayuna, NY
I think you are correct.. I would not expect you to be able to add non ford vehicles to your Ford pass. So you'd have use regular EA+ for the non Ford EVs.
monsterlag
AJ
Albany
F150 Lightning, Tesla Model Y Performance
where do you even see the option to pay Ford $50 for cheaper charging?
Edit - removed to eliminate confusion. (Mine!)
Regarding my last post, I’m not sure that’s even necessary. All you should have to do is pull up to a charger in your non-Ford EV, activate the charger in FordPass, plug in and charge.
Lightning.Dav
Temecula, CA
Sienna x 2
@monsterlag It's called the
BlueOval™ Charge Network Electrify America Membership
and is explained here: membership
edit to add: my truck isn't built yet. It won't let me go to the connected services page. Errors out.
greenne
Nathan
Niskayuna, NY
So basically this gets you the same benefits as paying $4 x12 months for $2 more, but with the added convenience of plug and charge
sotek2345
Engineering Manager
I have just recently started using the EA+ membership. We also have plug and charge turned on if we need want to plug in and go, but for longer trips we activate a month of membership for $4 and then turn it off after the trip.
You just have to remember to start the session with the EA app before plugging in to get the reduced rate.
I do agree, it could all be much simpler with better software.
Can anyone confirm?
You cannot link EA to FordPass. Correct.
Yes, there WAS an option to get that same rate for $50 a year. Then, it didn't work, and was yanked. Now it's being retested.
Yes, it's $2 more per year if you sign up with EA for 12 months. However, EA Pass+ allows you to sign up, then immediately downgrade and it takes effect in 30 days. If you travel all 12 months of the year, the $2 comparison is valid. If you travel 6 months of the year, then it's $24 ($4 x 6) vs. $50.
While you cannot add non-Ford vehicles to FordPass, you can swipe on a charger to activate it and then plug in any EV and pay for the charging with your FordPass account. I don't have any non-Ford EVs, so I haven't tried it, but the charger is activated by the swipe, and then you plug in. I don't believe that it tries to read that it's a non-Ford vehicle, or a vehicle not in your FordPass account.
I think if you turn on “Share charging access” in FordPass, you can charge your other EV using your Blue Oval Charging Network account.
No. That option allows you to add another user, i.e. spouse, who can then use THEIR FordPass account to also charge. The prior answer covers it though. Every shared user must have a FordPass account, and you've given them permission when they request it.
monsterlag
AJ
Albany
Thanks for the clarification, I don’t even see the $50 option anymore so I am guessing it’s still shelved. Good to know you can still just charge via EA by activating first.
