Pro Trailer Hitch Assist via OTA update for MY22?
Aspesi4
Boston
Volt
Ford is touting the Pro Trailer Hitch Assist feature as an added feature for MY23. However, this was a feature that was announced for MY22 as a feature to be added at a later date.
Has anyone seen anything that the Pro Trailer Hitch Assist will actually be an OTA update sometime in the future or will it be added only for MY23 and beyond?
danofcolo
dan
F150 Lightning Lariat ER
Its on my truck and it works. I have hauled my trailer twice and it is very helpful for adjusting the Weight Distribution Hitch.
Aspesi4
Boston
Volt
Just to confirm, this is a feature where the truck will automatically back up and align the ball with the hitch for you. Is that what you're referring to?
"Pro Trailer Hitch Assist is new to the Lightning and automatically controls steering, throttle and brakes to make hitching trailers easier. Pro Trailer Hitch Assist is standard on the Tow Technology Package, which is available on Pro, XLT and Lariat trims. It's standard on certain Lariat trims and the Platinum trim. "
vandy1981
Tennessee
Plumber
This feature was originally promised as a Fall 2022 software update for MY22 but the text has since been removed from the MY22 configurator. It's not clear whether they will honor that original promise for MY22.
Ford F-150 Lightning Pro Trailer Hitch Assist via OTA update for MY22? 1660228378769
Ford F-150 Lightning Pro Trailer Hitch Assist via OTA update for MY22? 1660228403936
  • Wow
Stlww18
St. Louis
2022 Lightning Pro, 6/3 blend date
I'm pretty sure the press release I read said any existing '22 Lightnings with the Tow Tech package would receive an OTA update to get the Pro Trailer assist
danofcolo
dan
Your right, I was referring to the smart hitch feature. I'm not sure that I would need the auto backup to hitch the trailer, the camera's are great, I have no trouble backing the truck up to the hitch.
OhanaLewes
Lewes, DE
Ford F150 Lightning
I am purchasing a used 2022 Lightning Platinum. I am curious to know if the Pro Hitch Backup Assist OTA software update did roll out to all Lighting with the Tow Technology package? Thanks
Not that I'm aware of, I've seen a live demonstration of it in April of 2023, they were not sure when the OTA for it would come, but hoping it would be at the end of 2023, keep in mind they also anticipated Blue Cruise 1.2 / 1.3 at that time ..... and we're still waiting for what now may be BC 1.4.
theaustinite
Ben
So I’m gonna bring this old thread up instead of starting a new one…
I have a 2023 Lightning Lariat ER with Tow Technology Package. I have the Pro Trailer Backup Assist, but it doesn’t seem to have the Pro Trailer Hitch Assist enabled.
It doesn’t seem not ask me if a trailer is already connected when I hit the button, it just goes to the list of trailers to choose.
I’ve seen some forscan edits in the ice forum that might enable it. Do these work for Lightnings?
KingStraasha
Kevin
Dayton, OH
2023 F-150 Lightning Lariat ER, Antimatter Blue
I made the changes to IPMA and APIM that are on the ICE forum, but couldn't find the right changes needed for ABS, so I didn't make the change. When I hit the button, it asks if a trailer is connected, but when I select No, it then says that pro hitch assist is not available.
We need to find the right ABS change.
theaustinite
Ben
Did you try below change to ABS? These are the changes I found, but have not tried yet:
APIM
My Orig: 7D0-01-03: 524D, 21E5, 3F
To Mod: 7D0-01-03 xxxx xxFx xx
ABS
My Orig: 760-03-01 (tel:760-03-01), DB20
To Mod: 760-03-01 xx3x -- Autohitch
IPMA
My Orig: 706-01-01 (tel:706-01-01): 8A50, A219, AE
To Mod: 706-01-01 xx xx xx5x xx-- ModuleFeatureCfg_AH
KingStraasha
Kevin
Dayton, OH
APIM
ABS
IPMA
Yes, I did see that but the original lightning setting for ABS were completely different and weren't listed on the FORSCAN spreadsheet so I was hesitant to make the changes.
@Ford Motor Company are there any plans in the pipeline to bring this feature to 2022 & 2023 Lightnings?
theaustinite
Ben
I can grab my FORSCAN files if needed, I have this feature on my 23.
edit: Attached, rename extension from txt to abt. Two files, one is the very first from late 2024 when I first received FORSCAN, no changes made. The later one is my most recent backup.
Both are exactly the same, and I see yours is a 2023 Pro, but I am going to play with it a little to see if I can make it work. Thanks!
KingStraasha
Kevin
Dayton, OH
So...for my 2023 Lariat ER, I have for ABS: 760-03-01 is CCDA 11. We are focusing on the 3rd number, xxXx.
So, by looking at the hex to binary conversion, @Firn has a 9, which translates to 1001. I have a D, which translates to 1101. The order goes: AFS (AFS) • CTA (CTA) • PIB (PIB) • AutoHitch (AH).
If I assume that @Firn 2023 Pro does not have cross traffic assist (CTA) while a 2023 Lariat does, then D is correct. Thoughts from the team?
I am not making any changes and will attempt to connect to my travel trailer when it is not in a storage garage. When I tried it before, it was in the garage and did not work.
