Intellibeam
Massachusetts
2022 Lightning Lariat-ER Iced Blue Silver
Please give us a like and subscribe. We'll be doing more Lightning videos in the future.
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Nice job, thank you for taking the time to do this. I appreciate how long it takes to put videos together.
Mike G
N. AL, USA
2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco Heritage 2Dr
I just did this today. There is no reason for step 1, removing the frunk latch bar. It's not in the way of anything and isn't an item that's required to be removed to get to something else.
Also the "optional" acorn nuts shown at step 5 are the outside mounting bolts for the "monobrow" light bar ("grill fascia lamp") and since that's not being removed don't touch them.
The gap in the inner frunk hood panel that the wires are routed through is plenty big so fishing the lines through there is probably one of the easiest things to do in this procedure.
Also, there is a common ground point just forward of the positive jump terminal to attach your ground wire to. You'll see about 5-6 other small ground wires attached to one ring attached to the body with an 8mm bolt. That's the one I used.
As for the fuses in the BCMC that's taking me a bit more research. According to the fuse box diagram (attached) the fuse that was used in the video appears to be fuse F22.
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. Lightning_Fuse_Box
And according to the docs that is the fuse for the Power Steering Control Module (PSCM).
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. Fus
So Fuse 48 is the Heated Rear Seat Module (end of the row that F22 is on), but I can't even find this Fuse 181 reference in the docs at all. I got this diagram from the PTS wiring manual today since I was having a hard time locating any other useful reference.
My light works, I just haven't decided what fuse I'll eventually end up tapping to get it to come on when the parking lights do.
Yeah, the fuse panel in the docs doesn't even show a fuse where that tap is going. In either the owner's manual copy or the wiring diagram copy in PTS.
Anyway I'll keep at it.
pstansel
Paul
Tolland, CT
F150 Lightning Lariat ER, Hyundai EV6
So my stuff arrived today for this but I will have to let it sit and stew for a bit :)
Intellibeam
Intellibeam
Massachusetts
Step 1 is so you don't wack your head on the frunk latch 3x before you decide to remove it =)
You also are using the wrong Owners Manual. Fuse 48 Is the Rear heated seat module and 181 is Headlamp control module. Attached is the correct image for reference. This is the link to the Lightning owners manual:
https://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2022-Ford-F150-Lightning-Owners-Manual-version-1_om_EN-USA_03_2022.pdf
Mike G
N. AL, USA
Yup.....I know....and I got two different ones today and supposedly both are for the Lightning and are accessed using links from the owner's account area for manuals:
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. Fuses
And the one in PTS supposedly for the Lightning is the same.
So what I'm getting out of this is that the very first fuse in that row (ahead of fuse 22) in your reference and video...is actually the rear seat heater fuse?
Edit:
I've just downloaded the one in your link and it's the second printing, whereas I apparently was looking at the first printing version.
Thanks for the link.
Mike G
N. AL, USA
It would be really great if PUTCO could put together a 3" t-harness to the front fascia lightbar to run that LED oval cause the connector that provides power to the lightbar is literally directly behind the cutout on the grill frame for the oval itself. That way the oval would come on whenever the lightbar does.
Connector C1004.
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. Lightning_Front_Lightbar_Connector
And here's what the connector pinout looks like:
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. Lightning_Front_Lightbar_Connector2
jredondox
Jorge
San Diego, CA
2021 F150
isnt this light suppose to have a boot up animation?
Anybody doing anything with the small Ford emblem on the Lariat+ tailgates?
Intellibeam
Intellibeam
Massachusetts
That's what I thought as well because it's on their site with it. So either it only does when you use the T connector or it never did. I installed another one today for a friend, still took me an hour, it had no boot animation either.
Sam James
Sam
Missouri
22 Ford Lightning Lariat ER, 21 VW ID.4 Pro S RWD
Accountant
Thank you for this! Excited to make the swap once it gets here.
PungoteagueDave
Putco has Lightning specific-versions of plug-n-play Ford emblems for both front and rear in the works, along with a light blade for under the tailgate, supposed to be out next month according to a person I spoke with there last week.
