Regenerative braking seems reduced over the past week
JustaProGuy
MI
Lightning
Anyone notice that over the past week or so it seems to take longer to stop with one pedal braking? Someone on Facebook posted about this and I have to agree. The one pedal braking now seems to take more distance to fully stop, not at 100% charge. Anyone else have this experience/feeling? SR Pro here.
Maxx
Nevermind, it seems to have been confirmed that @Ford Motor Company did an OTA update that increased the stopping distance for one pedal driving/braking. Disappointed, the previous version worked great.
If first part of break pedal is Regen, I may even turn off one pedal driving. Minimizing Regen and friction break at the same time may maximize tire life and range. Very curious to see how Rivian tires do with that high Regen.
timothyedwards
Tim
Canal Winchester, OH
22 Ford Lightning XLT, Nissan Leaf
I am very disappointed in the change. I loved the way the regen was before. I understand the initial roll off was agressive but they changed it way too much and made it weak. I am hoping in the future that there will be a "regen option" in settings you can choose mild vs agressive or something.
JustaProGuy
MI
Lightning
@Ford Motor Company Fix it.
sotek2345
Engineering Manager
Have you tried putting the truck in sport mode and seeing if it is any better.
I don't have my Lightning yet, but not looking forward to this change. I thought the Regen on the demo unit I drove a few months ago was a little on the weak side as it was.
vacasity
Michael
Central Coast California
Ford F150 Lightning 2022 XLT
i immediately noticed this when the OTA came. I liked the previous version and now i find myself rolling past the limit line because I don't want to use my breaks.
broncoaz
Cape Cod, MA
Sport mode regen is much more aggressive in two pedal driving that normal mode.
I don’t know about one pedal (I won’t use it since I drive so many different vehicles between work and home), but using the brake pedal in two pedal uses regen first before engaging the service brakes. I left the braking coach turned on for now, I consistently get 100% energy recovered while using the brake pedal in normal driving. If you really stab the brake pedal the service brakes are engaged, but on a normal stop it appears to be all regen.
VTbuckeye
Vermont
You can still use the brake pedal. We have blended brakes so whether it is in 1pd or you have to use the wide pedal, gentle pressure will be regenerative braking. Calibrating 1pd differently does not change the regenerative capacity of the system.
sotek2345
Engineering Manager
For me at least, it isn't about losing potential regen, but about how you want to drive the truck. Using 1PD and regen to stop, and timing it so you stop exactly at the line, is a skill that can add some more enjoyment to the drive. Not quite the same as a stick shift, but it is all we really have for EVs at this point.
break pedal? friction break? o_O
JustaProGuy
MI
Lightning
Yeah I had it timed now I have to let off the pedal sooner as the truck is rolling more before stopping:/
VTbuckeye
Vermont
I understand. Our bolt and xc40 EV were/are driven in 1pd mode. I also think that 1pd should be fairly aggressive in its calibration. You can get less by releasing the pedal less. You can not get more once you have completely released the skinny pedal. For everyone who says that it is too aggressive, just release slower. The pedal inputs are not full on/full off (any of the pedals, though a clutch pedal is closest to all it nothing). I was just trying to point out that if regeneration is the goal while stopping, 1pd or 2pd does not matter as long as the input is gentle and within the regenerative capacity.
JustaProGuy
MI
Lightning
Which update changed 1PD regen?
That's the mystery, I noticed it first this past Sunday and several others on Facebook also noticed it, someone mentioned there was an OTA for it but didn't provide details
