Lowering Lightning height by a couple inches
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I wonder what effect lowering 2" has on all of the sensors for parking, rear collision, etc.
PungoteagueDave
Does your Lightning have 20" wheels? Smaller 18" wheels would give you the lower height you seek. GL
Uh, no, the outside diameter of the various Lightning models with 18", 20" and 22" wheels is exactly the same. The only difference is tire profile (there is less sidewall height on 22" wheels than on 18" wheels, but the diameter is the same).
Sealevel
Martin
Memphis, TN
23 XLT Lightning SR
Engineer - Retired 2025
I understand what you are saying - 275/65 R18, 275/55 R20 and 275/45 R22 are all about 32" in outside tread diameter. I referred to several tire sites for Lightning Tire sizes. The 20" tire size listed for the Lightning is 275/60R20 which has an outside tread diameter of 33". That is where the height of the truck will be 1" lower.
VTbuckeye
Vermont
32 vs 33 diameter will result in 1/2 inch height change (only half of the diameter is from the ground to the axle center). The 18s will lower the truck a bit, but to get any significant lowering some suspension changes will be required.
Sealevel
Martin
Memphis, TN
23 XLT Lightning SR
Correct. My error. Good thing OP only needs 3/8" lower height. :ROFLMAO:
GurmukhHundal
Gurmukh
New westminster
Platinum Lightning, Lariat Lightning
Plumber
Belltech makes a direct fit strut for a 2013 f150 that utilizes the factory spring and fits the rear of our lightnings for 1-3" drop. I used them on my lightning for a while and ride was same as stock. Recently switched to a different setup to get even lower though. As of yesterday swapped all the parts from the white truck to the black platinum.
Ford F-150 Lightning Lowering Lightning height by a couple inches Adobe_Express_20230121_2308120_1~3
skyak
F250, 911, Lightning
Do you have a link to the belltech part or part #?
Deleted member 12322
Guest
Damn man that looks super clean. Any parts or install info? I'd love to mirror the look.
GurmukhHundal
Gurmukh
New westminster
Plumber
I've got belltech 25027 on the front and for the rear I've got "ride tech shockwave hq" air struts with a "wireless one" ride height control kit
That seems unlikely. The spare on my Platinum is smaller than the other wheels. If all Lightnings were the same size I would expect the spare to be the same as well.
brewski
GA
2023 F150L Platinum
Yes
Your black truck pictured is lowered how much?
PungoteagueDave
This
this is fact. The only difference in diameters is the wheel itself. This is true of almost all auto manufacturers. When my Tesla had a 19” or 21” wheel option, the outside tire diameter remained the same. That s that same for my Platinum Lightning vs the various other versions. My 22” wheels just have shorter sidewalls and bigger wheels, same diameter tires.
