Lowering Kit options for Lightning?
GurmukhHundal
Gurmukh
New westminster
Platinum Lightning, Lariat Lightning
Plumber
Hey Guys, belltech part number 25001 is bolt on for the rear and gets 3" of drop. Everything works as per factory specs except on board scales. There's a ridetech air strut that bolts into the rear for a 6" max drop, which is what I switched to now. Front is basically any ICE f150 lowering strut.
Ford F-150 Lightning Lowering Kit options for Lightning? PXL_20230127_225653714
Ford F-150 Lightning Lowering Kit options for Lightning? PXL_20230127_225025590
LightningMcqueen
Justin
Austin,tx
2017 F150, 2021 Bronco Sport
@GurmukhHundal what is the ridetch part number? How do you like the air shock?
I heard there maybe a camber issue at >3” drop on rear, did you have any issues?
ridetech says “vehicles weighing 1,500-2,500 lbs. per axle.” I would think this is not strong enough?
ScubaSteve
Steve
Missouri
2022 Lightning Platinum, 2021 GT500, 2017 Focus RS
Sales
Great looking stance!
How big of a front drop did you do?
How did you fix rear camber issue?
GurmukhHundal
Gurmukh
New westminster
Plumber
Hey, there's definitely negative camber but the tire shop maxed out to minimize it.
Ford F-150 Lightning Lowering Kit options for Lightning? Screenshot_20230201-213021
Akbrian
Alaska
F150 Lightning 2022
Anyone know if the front and rear springs are the same? I have a set of front struts/springs off a 19ICE was thinking going bell tech 25001 and mounting the 19 springs to use on rear.
Voxx23
Ken
Delta,BC Canada
2023 F150 Lightning Platinum
Boss guy
Did you do this or at a shop? If so, what shop as I am local to you. Need to do this to mine asap... thx
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Any updates on this? I have several questions. You did the max 6" drop on the Ridetech shockwaves? How's everything holding up? Do you hit the bump stops and if so, how did you change them?
Deleted member 20876
Guest
That's the nicest Lighting I've seen yet. Nicely done.
digitys
Keith
Concord, New Hampshire
2023 Lightning Lariat ER
IT Consultant
Hey following on this thread. Looking to do maybe 3 inches in the rear and 1-2 in the front. Love in a northern climate so snow is a factor but definitely want to lower it. Can anyone list all of the parts for the front and rear they used?
Throne
Dee
2025 Ford Lightning Lariat
Yeah it would be awesome if @GurmukhHundal let us know all the parts used, how it rides and such. Also even recommmended shops or shop that did his setup.
