How low can power be throttled in cold climates?
boggle
CT
MY23 PRO
Was bitter cold here over the weekend (-10F), noticed power was capped at 60% when I got in the truck (didn't precondition). After an hour of highway driving (9F ambient) and a restart it was only up to 65%. Battery SOC was 60-75%.
Most days it's closer to 80-85% from a cold start (~20F ambient) and it's fine, but 60% was rather noticeable when getting on the throttle. I can see this especially being a problem for those of us that tow in the winter without the luxury of being able to precondition in the field.
Just curious if @Ford Motor Company has provided anything about how low this number is actually allowed to go. Everyone always whines about the cold weather range, but I don't see much chatter about the power limitations.
Ford F-150 Lightning How low can power be throttled in cold climates? 1675695683520
Coming home Saturday with the SOC low and it bitterly cold out, my max power available was at 50%
I'd be interested to see what the temperature gauges looked like when your power was this low.
sotek2345
Engineering Manager
60% is about the lowest I have seen.
In our Mach-e we have seen it get as low as ~30% (no numbers, so just guessing from the "jail bars")
A couple ways that can help
- "High power events" can help raise the battery temp. "Stand on it son!"
- charging - either L2 or DCFC will raise the battery temp.
boggle
boggle
CT
MY23 PRO
Understandable with low SOC, in this case I was at 60% battery (will update the OP).
Battery was pinned to the left of the bar's IQR. Next time it happens I'll log the actual temps with my OBDII scanner.
Ford F-150 Lightning How low can power be throttled in cold climates? 1675696555107
boggle
boggle
CT
MY23 PRO
Going to see a bunch of us sledders/ice fishermen unlatching our trailers and doing donuts at trailheads/boat ramps just to get back home.
Joneii
Central PA
F-150 Lightning, Tesla MY
I saw power capped at 54% with the battery temp indicator changed to an amber color and at the bare minimum. You still have a bit of “normal” zone left in the picture. I was at 77% SOC with DTE of 69 miles (yes, it is an extended range!). It had sat overnight with no power at -23F. I couldn’t precondition either, but was able to return the battery temps to just below midrange by yo-yo driving (max accel/max regen, repeat) for about 5 miles. I did this on the way to the charger to be able to charge in a reasonable time. I think it is the fastest way to warm the pack, but can be tricky if there is snow or other traffic. I also don’t know the impact on the motor or other systems, but everything seemed fine (motor temp stayed right at normal)
As @sotek2345 said, the Mach-Es don't give a number. In fact, only the GT? / GTPE even shows bars, the Premium and other trims have no idea that power has been reduced, except when the car enters turtle mode if it has a very low SOC.
sotek2345
Engineering Manager
I have posted on the Mach-e forums that the non-GT cars are welcome to the power bars, as long as they agree to be in power jail as often as the GTs! :p
I LOVE how little the Lightning pulls power as compared to the Mach-e
It's interesting - I've enabled the energy readout on my Premium, but have never seen jail bars.
sotek2345
Engineering Manager
Lucky. The GT only has full power if it is between 60F and 80F, you haven't driven over 60mph in that last 30 minutes, and are at a high state of charge.
It also helps if the moon is blue and it is the 5th Sunday of the month.
If all that is true, you can have full power for up to 5 seconds.
LightningShow
MA
'22 Lariat ER
Product Development
I think the answer is that it just keeps dropping until the truck doesn't move. I don't know what the % would be at any given condition but I wouldn't be surprised (based on experience so far) if we'd be down in the 25% range if SOC was at 10% in subzero temps.
