Active Air Dam System Fault
YOALEXUS
Alexis
Indiana
Ford f150 lightning lariat
Pretty much everyone. The dam gets stuck sometimes and doesn't know what to do. It usually resets itself. Mine gets jammed on one side, I'm going to look at it in the spring.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
I was driving and out of the nowhere i got this error about the air dam, anyone having this issue?
I experienced this one time, it reset itself. Whether its weather related with snow, ice etc.
I look as it as same thing when I get parking safety sensors offline during freezing rain or ice and snow conditions.
vandy1981
Tennessee
Plumber
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Here’s the message.
Ford F-150 Lightning Active Air Dam System Fault C25E0542-F6F6-4B25-8279-379F09B0D7C3
p52Ranch
Bryan
OK
My dealer replaced one of my actuators that showed as bad. But I’ve got the message twice since the repair. I think some maintenance needs to be done on the path the air dam travels.
The entire air dam device seems to be very fragile and not one of Fords better ideas.
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Mine does it daily. I also got the dreaded External power drain message last Tuesday so I dropped it off at el cajon ford. The service advisor said they looked at the air damn and said it's functioning as intended.... I'm not surprised by the response but I'm coming to the conclusion that he's not wrong either. Seems like they just need to back down the error message sensitivity. I'm gonna disable my air dam and figure out how to turn it off on forscan.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
Mine has done it daily for the last two months. I am planning on having the dealer look at it next Friday when it is in to fix the cameras due to the water in my lightbar. That said, it was in the mid to high 70's on my way home from work yesterday, and in the mid 60's on my way to work this morning (55 miles mostly highway each way) and I didn't get the error. I can't help but wonder if it is temp related but I hope to get more info after my dealer visit which I'll gladly share.
Peddyr
Peter
New Hampshire
Cyber
72 degrees on the way home yesterday and no error. 42 degrees on the way in this morning, drove about 40 miles and got the error message getting off the highway.
Mike G
N. AL, USA
TSB 23-2126 For "Active Air Dam System Fault See Manual Warning Message In IPC" dated 26 May 23.
Basically, it says update the PCM.
LagSwag1
Casey
Palm Bay, FL
2022 F150 Lightning Lariat
GM Software Engineer
Thank you for sharing. Just scheduled an appointment for this weekend to get this fixed. Been bothering me since i got the truck last year and its the single issue i've had. So will be nice to have it resolved!
