Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco HLE 2Dr
Perzackly. Well said!FWIW I was able to update fine for about an hour using a single 20A Clore. I would recommend, if you’re doing that, to have it charge up your battery with the truck off in charging mode first until it’s 95% or more complete. Then switch it to PS mode.
And during programming keep an eye on the voltage drop. If it gets into the 10.x volt range, take a break and recharge the battery again before the next set of updates.
