F150 Lightning FORscan thread
gorwell
Sacramento
Ioniq 5 / XLT Standard
Loaded up forscan for the first time to get familiar. Changed the blinker count as a test.
I noticed a dtc for ipma, any one knows what it means?
Truck having zero issues, also just came from 10k service on Friday where I am pretty sure they ran diagnostics.
Code: B115E - Camera Module
Additional Fault Symptom : 31):
- No Signal
Status (-28):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Image Processing Module A
Jlarbeypro
Ozark MO
2024 Flash
PA-C Urology
Whole lotta nothing. I see lots of old dtcs , even after deleting them
MickeyAO
Mickey
San Antonio Tx
Is there a setting I can change for the speed at which the front camera will come on or off? I think it is set to 7mph which is way to slow...I would love to set it at 10mph.
I thought it was going to be the camera at speed settings, but after going through all 35 pages, it appears that is for something else.
Adventureboy
I'm very interested in this as well. I don't have my lightning yet but would love to enable glare-free if possible.
I would expect at some point the USA will allow the truck to be shipped with this active. We have it active already on delivery in Canada. Very nice feature.
chillaban
2022 F-150 Lightning Lariat
I'm honestly not as optimistic about that. The USA (NHTSA) approved adaptive headlights are based off a new SAE standard. The Canadian approved ones follow Europe's UN-ECE standard.
That seems like quite a bit of software work to validate and tweak the adaptive headlights and open Ford to the risk of a recall if for whatever reason it doesn't comply with this fledgling SAE standard. (Remember, GM barely fell out of compliance with glare requirements on the GMC Terrain and literally had to issue a recall where the fix was a 1 inch piece of translucent tape)
If I were Ford I would just leave it alone until the T3 platform.
Blochead21
PA
Black 22 XLT 311pkg
Just saw there were some new updates to the Forscan excel sheet. I haven’t been able to test them yet but knew there would be some interest.
Remove "full view not available"
Ford F-150 Lightning F150 Lightning FORscan thread IMG_5867
Pet mode?
Ford F-150 Lightning F150 Lightning FORscan thread IMG_5868
WhiteYeti
NJ
F-150 Lightning Lariat SR
I have a 2022 Lariat SR currently without the Rain Sensing wipers. I would very much like to add them. After reading through this thread, it seems like it is possible, but some of the information is a bit old at this point and wanted to know if anyone has done this recently. There is a link to the rain sensor itself from infotainment dot com back in the thread, but it appears that the link is broken. Currently infotainment has this product -
2021-2023 Ford F-150 & 2023+ Super Duty Factory OEM Automatic Rain Sense Windshield Wiper Upgrade - Infotainment %
which seems excessive (i.e. has more than you need) based on reading this thread. Is it possible to get the rain sensing wipers using just the sensor and Forscan programming? here is a link I found to just the sensor.
2011-2023 Ford Rain Sensor LU5Z-17D547-B | TascaParts.com
3rdgenfan
Geoff
Delaware
Cybersecurity
I added rain sensing wipers with just the sensor and the FORScan changes. You should be fine but I would pull down the plastic piece above the rearview mirror and make sure you have the connector tucked up in the hole where the sensor goes.
I assume you'll be fine with it being a Lariat but only takes a second to check.
WhiteYeti
NJ
This may be covered in the thread, so apologies if I missed it, but what is the easiest way to remove the cover? It doesn't look like there are any screws?
3rdgenfan
Geoff
Delaware
Cybersecurity
It's locked in with two or three clips. So you can just kinda pop it off.
Don't have a good picture of it but you can see two of the clip bosses here:
EDIT: Actually, this pic shows exactly the area you need to work in lol. The connector for the rain sensor is that little 3 wire tucked into the plastic clip in the center.
Ford F-150 Lightning F150 Lightning FORscan thread PXL_20230224_210724599
WhiteYeti
NJ
Just checked, and the connector looks exactly like your pic. Thanks!
just as an update, after MANY thousands of miles after adding Radar for ADAPTIVE CRUISE to my PRO, removing the 'frunk beeper', and using Forscan to also remove 'auto door locking at speed' and disabling 'seat belt reminder'... and adding a new 'wireless' Keypad in the Charge Port door.
ALL IS WELL
Adaptive Cruise, Lane Centering, and 'Slow down, Stop-N-Go' Cruise is all working and is great in making driving a PLEASURE, especially long-distance travels, EVEN with the camper in tow. While there are a few moments or instances where you might wonder 'why' the truck suddenly slowed down, or 'thought' it was seeing a vehicle still in the lane in front, even though the vehicle is now in an adjacent turn lane... oh well.
The removal of the 'frunk beeper' cannot be understated: no one is none-the-wiser when I 'pop' open the trunk, or go to close it. Nice. Quiet.
The disabling of auto locking and seat belt reminders also makes starting a drive so much more pleasant. No 'beeping', 'dinging', and 'warnings' for us 'old' folks who have been driving for ages and learned back in the day when NONE of these 'alerts' were anywhere in anyone's forthoughts, or needs.
The 'wireless' Keypad is a nice addition, and has already come in use several times when the FordPassApp takes too long to 'unlock' the truck(cellular? signal)... and so having the ability to simply pop open the charge port door, enter the code, and have the doors unlock, is a plus, and actually makes the 'range anxiety' for the App a thing of the past : )
My wife appreciates it too, as she no longer has to text me when she is trying to enter the truck, and can just use the keypad, if needed in a situation where she needs to get into the truck before I do.
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
Pet mode?
Has anyone with a Pro (no options) tried this APIM change to remove black box? Tried it today (current value 4 changed to 5) and I received error messages when attempting to write. My other ForScan changes have gone fine. Not sure if I’m doing something wrong…or not working on a no option Pro.
Thanks everyone!
Blochead21
PA
Black 22 XLT 311pkg
I just enabled it on my 311 XLT. Did you force reset the apim module? I also cleared all dtc’s after the reset. Worked fine for me.
Removes black box from the rear view when in drive.
Ford F-150 Lightning F150 Lightning FORscan thread IMG_5890
Also gives the radar warning for the front in the corner view until you switch back to the 360 view.
Ford F-150 Lightning F150 Lightning FORscan thread IMG_5891
wautard1
Eric
Seattle
23 Lightning Lariat
Can anyone confirm that the Forscan details at the beginning of this thread is the most up to date list of Lightning confirmed mods and data entries?
Asking since the thread is over a year old but still stickied.
