Heated Steering Wheel Retrofit PU-22G06
So…has anyone actually gotten this done yet? Are the parts available or not?
My dealer has the parts and I’m scheduled to have it done this Thursday (Oct 5). I’ll report back on the result.
zeus2023
Louis
Lightning Lariat ER Agate Black Metallic
My 23 Lariat ER was repaired last week. Heated steering wheel appears to work well (esp. in 95+ heat).
I do have a minor problem in that the turn signal indicator is "binding" when I use right turn.......
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
My truck has the 50 dollar wheel removal credit. Will it eventually get the heated wheel back?
You should. Go into the FordPass app and click on the service icon at the bottom. There should be a tile for Customer Satisfaction Program and if you click it the bulletin should be listed there.
Ford F-150 Lightning Heated Steering Wheel Retrofit PU-22G06 IMG_0253
Fastmikerx7
FM
Renton Washington
2023 Lariat SR
.GOV
I pinged my service advisor about when will the parts to get my steering wheel heat going be in.
Here was his response:
I will let you know when it comes in, I will be the first to know and then I can let you know!
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
So I had my truck in yesterday for the 3 CSP's on my truck. Was told by the dealer that the parts for the heated steering wheel CSP aren't available yet according to the people in the parts department. So it seems like I'm not getting the full story.
Arrington.LCA
Luke
Colorado
Heated steering wheel parts are on backorder at my dealer in CO, and they have no estimate on time. They think the light bar parts are like a week. Trying to do all my stuff at the same time. No mention of any cost for steering wheel. They did try and schedule my 10k service for $119 (oil, multipoint, and tire rotation) or $107 for just oil and basic inspection. Seen others here getting the 10k service for like ~$70.
Seriously, oil?
The 10K on my Mach-E was $14. It will be the same for the Lightning.
Webbo85
Marc
Glenmoore, PA
Mech Engineer
I just paid $31.78 for my 10k check up. Basically a tire rotation and fluids
KennyB123
Ken
Detroit, MI
Oil? Are they throwing in blinker fluid too?
My appointment was today at 2:00PM. I dropped the truck off at the dealer mid-morning because I was out that way for other errands. Dealer calls at 1:15 telling me it’s done.
The only downside is that they performed a master reset, which really shouldn’t have been necessary. Maybe they ran into some unexpected issue?
I have everything set back up and all seems well. I got the new dash mat also.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
I received the letter from Ford. I contacted my dealer and I have an appointment set for next Friday. He wants to assess my truck and order parts for the lightbar and steering wheel. I also received a letter from Ford a week ago stating that I will have a battery module replaced, free of charge, as part of a maintenance process with the battery. My dealer is going to look at everything next week.
That’s crazy. My dealer doesn’t schedule me in until they have the parts in-hand. And they don’t physically need the vehicle to order the parts.
They are supposed to do a diagnostic and/or troubleshooting before ordering any warranty parts, at least here in Canada. Maybe your dealer has a high volume of lightnings going through and they know what they need.
My dealer services 2 Lightnings, mine and the FCTP they sold. I’m pretty sure the part numbers required are listed in the technical instructions for the CSP.
davehu
hot springs, AR
Heated steering wheel parts are on backorder at my dealer i....
I called my dealer about the time you posted that (Oct 5). Dealer called a week later and said the part had arrived. I'm scheduled to have it put in Thursday.
