Tire pressure recommendations?
Jseis
Washington
43-45 psi here. Contributes a bit to my 2.5 mi/KWh 12,400 mile average.
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2023 Tesla MY, 1941 Lincoln V12
I go by the door jamb sticker, so add air for winter temperatures. As for traction, low pressure helps on sand but not snow. Low pressure concentrates weight of truck on outer edges of tires, causing poorer contact in middle. Maybe higher pressures even helps in snow.
Monitor tread wear. If middle wears more, pressure is too high. If outsides wear more, pressure is too low. If outside wears more on one side of a tire than on the other side of the same tire, get an alignment ( and your range will increase).
Dan's Lightning
Dan
Victoria BC Canada
F150 Lightning Lariat Extended Range
47psi cold. Driving they warm up to 49psi this time of year.
I love the feel what a difference in turning, handedly, rolls way better, better range I found to.
This is a very heavy truck!
Stand on the side of the wheel and look at the bottom contact of the wheel and look at the sage of the tire! It will tell you right away that you need more air for this beast of a truck nearing 7,000lbs.
The dealer gave me the truck at 36 lb and it's was awful I almost hit a Highway divider when I had to do a quick maneuver, tires are way too soft at 36lbs, what are they thinking? At 47 lbs it's a world of difference and much safer I find to. Haven't noticed any loss of traction at 47 lb this truck weighs so much you going to have a lot of traction either way. I'm going to try 49lbs cold soon, this truck is so heavy you need to max out tire pressure especially on these stock tires. I'm going to be looking for new tires for this truck soon and look into ones with Max 81 psi. I have a Ford E250 Cargo Van and it has 81 psi max tires on it! Got to get better tires on the lightning than the stock ones...
BuzzLightning2023
BuzzLightning2023
Los Angeles
92 Explorer,94 F150,06 Avalanche,05 F250,11 F150
That’s gotta be a stiff ride at 47-49 psi.
BuzzLightning2023
BuzzLightning2023
Los Angeles
Not at all, when I set my stock AS to 42 cold, they often rise to 44-45 after spirited driving.
Pay attention to the one that went low, might have a nail hiding in the tread
Pulled up at my tire shop and there it was right on top. They fixed it in the street faster than I could go inside and pay. I had the guy save the screw so I could see if it was friendly fire or not. Not.
Ford F-150 Lightning Tire pressure recommendations? IMG_4385
Dan's Lightning
Dan
Victoria BC Canada
Stiff ride at 47-49? Not at all.. you got to be kidding me..
See pics. My truck's been sitting in the driveway all night this morning tire pressure and pictures of the tire cold, I can still see sag at 47lbs., the front tire 46lbs, more sag. Definitely not a stiff ride, I find it just right at 47 psi cold. This is one heavy truck got to get the tire pressure up i self learnt...
Note: This is a Lariat Extended range, they are heavier than a standard range..
Ford F-150 Lightning Tire pressure recommendations? Screenshot_20231213_100549_FordPass
Ford F-150 Lightning Tire pressure recommendations? 20231213_100503
Ford F-150 Lightning Tire pressure recommendations? 20231213_100439
Labs4Lightning
C
Keep an eye on that tire. One tire going that low, compared to the other 3, points to a nail in it.
Are you leaving out the screws?
I’ve Far more screws than nails.
Ford F-150 Lightning Tire pressure recommendations? tmp
mefly2
j
W Montana
23 Lariat ER / KO2s max tow ; 22 F350, 23 C8 Vette
Retired CSc/Math teacher. LEO
Watch the tread wear ... worn outside - too low a pressure; worn center - too high.
I just topped off my four to 50... ready for a 300 mile trip tomorrow. The ride home from the tire shop was NICE and COMFORTABLE and SMOOTH... I felt NO difference one way or the other, before at 39, or now at 50. The Michelin Primacy XC tires state '51 max psi'... The truck does NOT know what tire, or what type or size tire you have, so I don't know why going by the 'door sticker' would be the 'rule'...
BuzzLightning2023
BuzzLightning2023
Los Angeles
This thread brings to mind 2 things: 1) That iconic Life magazine pic of the father and son who over-inflated their tractor tire and it exploded (taking them with it) and 2) Fear and Loathing in Las Vegas where Hunter S. Thompson convinces the gas station attendant that the tires on the Cadillac are new/experimental technology and to please fill them to a ridiculously high psi. ?
The low pressure setpoint is set to whatever tire you had on the truck when delivered. That is why its recommended to set pressure by the door sticker.
Maxx
There are a lot of benefits to more air pressure but one of the downsides is more weight needs more stopping power in emergencies. And that means larger contact patch (less pressure).
PV2EV
Reduced mine from 42 to 38 in hope of 1. less slipping in the wet (20" AS @ 12k miles) and 2. preventing another destroyed tire from a gravel puncture!
Will inflate them next week before a big holiday road trip.
