Possible to change max low HVAC temp in Forscan?
LightningCanuckNB
NB, Canada
Is it possible to change the MIN and MAX temps the HVAC makes available? For reasons unknown Ford made a bizarre decision to arbitrarily limit them... you can only lower the temp to 60 degrees F/15.5 degrees C... if you set it lower, it just totally disables the heat and says "LOW".
60 degrees might be a fine max low in the summer but it is freaking high in the winter time when one is wearing a winter coat with heated seats etc. It's just wasting tons of electricity and actually makes me uncomfortably hot. I would like to set it more like 50 degrees F / 10 degrees C or maybe even a bit lower. Is this possible?
MickeyAO
Mickey
San Antonio Tx
Since you are wearing your coat, have you thought about just turning off the HVAC and use the heated seats and coat to stay comfortable?
The real problem is that the temp setting has little connection to reality. I was driving the other day with it set to 66. The air temp near my head measured 72 and heat was still pouring out of the vents. It seems like the colder it is outside, the warmer the cabin gets on a given setting.
Does routing the air output to defrosters only help with your comfort?
lightspeed
2023 Lightning Lariat ER
You can explicitly turn off the heater in the large HVAC screen with the vent controls that popus up.
LightningCanuckNB
NB, Canada
Thank you for all the tips and tricks on clothing and heat - I am just trying to find out about the ability to alter this setting on FORScan. I can not find anything in the control modules for this but I am far from an expert.
I've never heard of this and don't recall seeing it when I stepped through the settings in Forscan a few months back. Best I recall 60 degrees has always been the low in most every car I've had with an auto HVAC.
My 2013 Explorer goes to “LO” one step below 60F. That’s what I use in mild weather, no AC, vents only.
I have seen LO on some as well, but have to admit I figured that was same as 60 or maybe 59, just a different indicator that you really can't go below 60. Maybe it truly does, but I've only used that temp setting for AC, not heat. I don't think I've turned the heat down below 66 or 67.
Yeah, I have no idea what I’m accomplishing. Just trying to make sure no heated coolant is directed to the heater core.
LightningCanuckNB
NB, Canada
LO when you have heat enabled means that it's just using vents... it's bringing in the outside air. Which in my case in winter is way below 32F. I don't want that. I want 45-50.
BSull
Robert
Mesa, AZ
23-F150 Lariat ER, 17-Mercedes GLC300, 19-Vette Grand Sport vert
I don't get the complaining about HVAC settings in the Lightning. Have ya'll ever been able to set digitally controlled temperature in any car including ICE lower than 60? I cannot remember ever being able to do that. I just got rid of a 03 F150 ICE lowest setting was 60, wife's GLC300 lowest is 60, 'l9 vette lowest is 60. What gives?
LightningCanuckNB
NB, Canada
What gives is, the heat here is not waste heat from the engine, it is all coming from a heating element that should be able to be much more directly controlled.
BSull
Robert
Mesa, AZ
That has nothing to do with how low you can set the thermostat. Like others have said, use the seat and steering wheel.
