LightningCanuckNB
- Jan 19, 2023
- NB, Canada
- F150 Lightning
Is it possible to change the MIN and MAX temps the HVAC makes available? For reasons unknown Ford made a bizarre decision to arbitrarily limit them... you can only lower the temp to 60 degrees F/15.5 degrees C... if you set it lower, it just totally disables the heat and says "LOW".
60 degrees might be a fine max low in the summer but it is freaking high in the winter time when one is wearing a winter coat with heated seats etc. It's just wasting tons of electricity and actually makes me uncomfortably hot. I would like to set it more like 50 degrees F / 10 degrees C or maybe even a bit lower. Is this possible?
