Frunk Only Opening 1 Foot then Stops
jfb130
Jason
F-150 Lightning
I used to be able to open my Frunk with they key fob and it would open the entire way. Now when I do it, the frunk opens 1 foot then stops and you have to open it the rest of the way manually. Any ideas?
Try recalibrating the opening height
Ford F-150 Lightning Frunk Only Opening 1 Foot then Stops 1703889366905
Ford Motor Company
Official Ford Account
F-150 Lightning
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
jfb130
Jason
F-150 Lightning
Let me know what they say because I still haven’t figured it out.
jfb130
Jason
F-150 Lightning
Let me know if you find a solution mine still not working, right
3121
2022 F150 Lightning Lariat SR Mannequin
Pop the frunk and then manually push it all the way open. Then press and hold the close button, keep holding until it beeps.
This is a feature so you can prevent the frunk from opening to high and hitting something. For example if you have a low ceiling garage.
rsinow
Rob
Spring Hill, KS
2023 F-150 Lightning Lariat
I've already tried this, it did not help.
3121
Just double checking - You are holding the little round button on the frunk itself? not the button in the cab right?
Assuming you've done that... the only other thing I would try is pulling the negative 12v battery cable for an hour or two. Reconnect the 12v battery and let the truck boot back up for 10 min. Then pull the frunk closed manually (get it to the latch and click it down, the latch will grab from there). Try and open it again. If it's still opening a small amount try to push it up manually and press and hold the frunk button again.
If that does not cure it you will need to take it to the dealer.
rsinow
Rob
Spring Hill, KS
Yes, I did push the button on the Frunk. I'll look into the other suggestion, thanks.
Gaffer
Southern California
Motion Picture Lighting Designer
Mine just spent a week in the dealership for this exact issue. Just got it back and it’s working now. Looks like from the invoice, they had to replace both power hood struts. Nothing tested faulty they said, that’s why it took a week, they were testing everything. I think in the end they just replaced the struts and it started working again.
beast
NC
Ford lightning XLT SR 312A
Add me to the list fellows of issue just started today. Tried resetting and same thing. Only does a foot every time
beast
NC
Update everyone. Swung by my dealer, showed him my issue earliest to get me in is Feb 24th
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
Did they end up fixing/ programming it?
