Power-Up: Smart Changes: Improvements to your vehicle diagnostics
Labs4Lightning
C
Meanwhile, on version 4.x…….
@PreservedSwine
As reported in the fdrs topic.
there has been some talk of updates being “stuck” if I remember,within FDRS, it shows you have a both a gateway and a sync update - it might be stuck.
so getting the gateway module update seemed to OTA to behave normally.
again, from memor, also thought same was observed in Mach-e
but then again it was a little anecdotal
if you‘ve only had your truck for 2 months or less, just be patient
Formerly
NY
Ford Lightning 2022
Construction Estimation
Dumb question, is there an easy way to see what version you are currently running?
WoodduckMN
Andover, MN
23 Tesla Y, 22 Lightning Lariat, 21 Chevy Bolt, 13 Ford Explorer
Manager
I received 6.8 in December and this unnamed one last night.
What version of what? You can see what Sync version you're on in the "about sync" page in your touchscreen settings menu. If you want to know where you are in terms of power-up updates, I can check your OTA history with your VIN to see what it shows.
Edit: This is the same no-name GWM update that were sent to the Mach E's.
The Weatherman
Dean
South Central KY
Just had a thought about this update.
Wonder if this might be preparatory work in advance of the Tesla Superchargers opening up. ?
VTRedWingsFan
Vermont
2023 F-150 Lightning Lariat ER, 2020 Escape
IT delivery
Received this update today. LVB data from last 2 days.
Ford F-150 Lightning Power-Up: Smart Changes: Improvements to your vehicle diagnostics IMG_2119
VTRedWingsFan
Vermont
IT delivery
Are these reports from a special app ?
Sorry, if I recall you're an Android guy. It's an IOS short cut. I started with this base and made my own for the LVB.
Yup, I'm an android operator, I created a desktop shortcut for the URL, three clicks and I have the data.
Wonder if this might be predatory work in advance of the Tesla Superchargers opening up. ?
No updates should be needed for the Tesla chargers.
USA EV
My truck received an OTA update (away from my home wifi, btw), and I can't seem to find the version. Past ones have the version right in the notification message. I checked in the truck and it looks substantially the same as this info:
Ford F-150 Lightning Power-Up: Smart Changes: Improvements to your vehicle diagnostics Screenshot_20240124_211404_FordPass
What am I missing?
What am I missing?
It has no version number.
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
Hey thanks for the info. When I try to run it I get the error “A server with the specified hostname could not be found.” Any ideas what could be wrong?
Ford F-150 Lightning Power-Up: Smart Changes: Improvements to your vehicle diagnostics IMG_3550
