Magendi
Philly area
Lightning Lariat
This is no longer a feature. It was briefly an APIM update but since then another APIM update released reversing this feature, mainly because allowing the truck to stay in Off Road mode is a federal regulation violation and resulted in a NHTSA recall.
They could’ve restricted that behavior to just Sport vs Normal mode but instead they reverted the whole thing.
Damn! That’s the major reason I ponied up for a mongoose and power supply!!! I hope someone figures out how to make sport mode persistent. Also hoping it wasn’t all for naught and that maybe I will get some OTA updates now that I have done the heavy lifting updates by wire.
Thanks for the quick response.
dugiepts66
Doug
Oakland, CA
'23 F150 Lightning Lariat ER- Azure
Tech
Alright, 100amp charge arrives tonight. Is there a way to redo/reinstall the Ipma and/or make sure it took?
Based on your previous post, disconnecting FDRS when the IPMA update hangs at that part of the process is the right thing to do. Sometimes it causes problems, and sometimes it doesn't and it seems like you got lucky and nothing happened. I would need access to FDRS which I don't have until later to confirm if it went through or not, but it sounds like it did. Restart the laptop and rerun a network scan. If the IPMA update is no longer showing, it should be in there. Make sure you clear all codes with FDRS if you haven't already.
ditkafan1985
NOVA
2023 F-150 Lightning Platinum
Just finished installed software updates. Avoided the PCM but accidentally selected ABS and it ended up updating the PCM as part of the dependent updates. Seemed to install ok. Unfortunately, FDRS crashed when verifying GWM software update. When I restarted FDRS the software update had disappeared from the SW Update tab. It keep throwing this error after every subsequent software module I updated. When I would clear and retest it would pass and be green. is this something I need to worry about? Should I try to reinstall the GWM software. I went looking for it but wasn't sure how to do that. How should I proceed?
Ford F-150 Lightning ECU module programming guide using FDRS Screenshot 2024-04-22 144650
Same thing happened to @dugiepts66 a few days ago. There's an SSM about it. Nothing you can do about that for now.'
Ford F-150 Lightning ECU module programming guide using FDRS SSM 52008
dugiepts66
Doug
Oakland, CA
Tech
While I'm not excited per se to have someone hanging with me in this limbo stage, I welcome you ditkafan1985. We shall endure this together.
If Ford released an SSM about, believe me, it's a bigger party than just the two of you.
Mike G
N. AL, USA
2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco Heritage 2Dr
I'm told this morning that it is okay to resume updating powertrain modules again.
That means if you select any of the PCM, ABS, BECM, GFM2, SOBDM, SOBDMB, SOBDMC then it will start the scripted (coordinated) update of all the powertrain modules (meaning you can't just cherry-pick one out of the list without doing all of it's friends).
Normally to clear the SOBDMC DTC that you quite often get after doing updates, (not just powertrain but other stuff as well like BCM and RFA and stuff you'd think is totally unrelated) you head back to the "View CMDTCs" button and then run a clear and retest to get rid of it. Sometimes that doesn't work and it might stick. As long as you aren't left with a SVS or SSN that sticks around after a few key cycles you would be okay.
artificial_airspeed
Fort Worth, Texas
2022 Ford F-150 Lightning | Lariat SR
I saw a post in the other main update thread about holding off on any powertrain updates. Is that the case as of 5/1?
Mike G
N. AL, USA
That is the case as of right now...6 May 24.
This appeared in PTS/OASIS this morning:
Ford F-150 Lightning ECU module programming guide using FDRS FSA_23B57_pause_6-May-24
Which essentially means...don't update your powertrain modules until we put out an updated set.
On another note......those IOTA Engineering, 120Vdc to 12Vdc, 90A Converter/Charger are selling on Ebay for $179. And the seller is saying something about this price ending on the 30th of April...but at the same time the seller says they have 5 left at this price at the time of this writing.
Here's the current link if you're interested.
It's a hellofalotcheaper than what Grainger wants for the Schumacher INC 100 :oops:
ditkafan1985
NOVA
I couldn't recommend the Schumacher INC 100 any more... but why its 1000+ on ebay when you can get it shipped off amazon for 600 is beyond me ...
Mike G
N. AL, USA
It's the "Grainger tax" !
Mike G
N. AL, USA
Ford F-150 Lightning ECU module programming guide using FDRS 40-4-5_7-May-24
