Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco HLE 2Dr
1 May 24 and there are three more updates in FDRS this morning.
BCM and the two door modules. This appears for both '22 and '23 MY trucks.
Mine also shows the FHCM from last week.
EDIT: I ran these this morning and started with the doors, then the FHCM and ended with the BCM.
The BCM software did update fine...but failed at the end step where the config is written back to the module. Don't know why...tried several times. Says there's an "exception writing to the module". Truck works fine, and at some point they'll figure out the config issue. Left with no DTCs at the end.
Post back if you have the same experience (or different?).
