It's all your fault man! I love doing things like this but was hesitant, you got me on board and I love all the support from the forum and want to contribute. :D
Ford F-150 Lightning Lightning Software Updates using FDRS you-got
"Y'all got any more of them updates?"
pkirby11
Kevin
Champaign
F150 Lightning Lariat
Well I did send a bug report and I did get the same error you mentioned Mike G, so hopefully they got it. I did not get any emails as of yet either. Just wanted to give you a little update.
techmatters
Pennsylvania, USA
'23 Lightning Lariat ER Antimatter Blue
Same here, I filled out the bug report and attached a screenshot of the NATSF login screen, then when I clicked submit, I got the connection error. I did this on Saturday and haven't received any acknowledgement.
Maineiac12
Iowa
I’m getting closer to pulling the trigger on a mongoose for myself but I’m debating on which power supply to get.
Does the Clore 6100 really need a 20a outlet to work? I’ve only got regular 15A outlets in my garage (on a 20A breaker)
What are some other good power supply options?
Runaway Tractor
Yes
At full load, yes that power supply correctly requires a 20 amp outlet on a 20 amp circuit. It will pull more than 12 amps, which is more than the 80% of a 15 amp circuit they can design for. 14.9vdc at 100 amps + 15% inefficiencies is about 1700 watts, which is 14 amps @ 120vac.
If you have a 20 amp breaker with 12 gauge wire, just change an outlet out to a 20 amp outlet and you're good to go. That would be better and probably cheaper than modifying the cord.
sstevetx
Steve
I bought one of these to get a 20a plug. 4-Prong Nema 220V 14-50p to 5-20R/15R Female Adapter Power Cord, Generator Cord with Surge Protector Breaker for 20V 15/20Amp Household Orange 1.5FT https://a.co/d/145QvlN
invertedspear
AZ, USA
lightningcalcs.pages.dev
Because you needed to step down from the outlet your charger plugs in to? I'm not sure what problem this solves in the context of this thread. Though I thank you because this will absolutely help me since the only outlet within 20ft of the end of my garage is the one my charger plugs in to, so I can stop using my truck to power random yard tools since the bed of the truck is the most conveniently placed outlet.
sstevetx
Steve
I only have 15a plugs wired in my garage that are shared with the rest of the house. My 14-50 receptacle is on a dedicated 50a breaker, so that adapter gives me a dedicated 20a plug in my garage suitable for the Clore 6100. I plan on wiring in a dedicated 20a plug at some point, but this works for now
Maineiac12
Iowa
What are everyone’s thoughts on using 2 PL2320’s instead of a single 6100? Looks like a couple people have used that setup with no issues.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
I’d think that is possible option, just not what I did.
I went with a different option to use for other things later on personally. It ran me about $110
https://a.co/d/0fGmKLjF
Ford F-150 Lightning Lightning Software Updates using FDRS IMG_1742
mr.Magoo
2022 Lariat ER, AMB
Power supplies have been discussed at length in other threads and people have as many opinions as there are options :LOL:
I did, for the longest time, get by with just one Clore PL2320 although it was getting "uncomfortable" a few times, so I figured 25% more omph would make it "safe" and I got a 25A CTek (it was around $400-500 so not cheap by any means, but it ticked all the boxes in what I wanted, compact, long leads, etc.).
I ran an update with it (the 25A supply) and this update took over an hour and at that point my voltages dropped to 9V and I thought for sure I was going to brick my truck.
That was my "oh s-it" moment and I immediately ordered a Schumacher INC100,
which is a good option as well, and came to the realization that our trucks can draw upwards of 70A during an update. At the same time I had learned about the IOTA DLS-90 which I ordered as well. The Schumacher went on sale shortly thereafter (I paid $600) and the new "normal" price is around $450 (same as Clore PL6100) and because Amazon doesn't do price match or credits I just returned mine and ended up staying with the DLS-90.
Here's my opinion on power supply options...
  1. In general, anything less than 50A is suboptimal.
  2. 2xPL2320, while it most likely will work, the 2.5-3hr updates should be "interesting" and there's in my opinion absolutely no reason to go with this option since the IOTA is only $40 more, the Pyramid is less, and both are much less of a "hackjob" connecting.
  3. Both the Schumacher and Clore PL6100 are nice units and a nice option if you need a powerful charger in addition to the power supply. I would personally pick the Schumacher because it has a 15A plug.
  4. The IOTA DLS90 has to be the best value on the market today at $200 (I paid more for mine). It's a solid unit, very clean 12V/13.6V output and has a 15A plug.(the 75A version has a 20A plug for some reason). The downside is that in in it's standard form it's only a power supply and you have to figure out the cabling (alligator clips or hardwired like I did on mine) yourself, so the first time setup is more complicated than it would be with a ClorePL6100 or Schumacher INC100.
  5. I have no opinion on the Pyramid unit above, seems to work for @ScubaSteve_TheReal so it's an option although it is on that 50A "limit"
  6. I would NOT recommend using one of the 50A $30 / 100A $60 power supplies on Amazon. Even though they "should" work from a (short term) rating standpoint (50/100A), you typically get what you pay for and I wouldn't be too surprised if they go up in a cloud of smoke after continuously supplying 40-60A for 3hrs. (IOTA,Clore and Schumacher all have built in cooling fans for example)
Maineiac12
Iowa
[*]The IOTA DLS90 has to be the best value on the market today at $200 (I paid more for mine). It's a solid unit, very clean 12V/13.6V output and has a 15A plug.
So you have no issues with the Schumacher on a 15A outlet?
What voltage do you set the charger at?
Gimme_my_MME
Looked around and found a screen shot, this is what I was getting when trying to perform the BCM update in FDRS:
And this is what I saw if I tried to log in with an NATSF account, which didn't work:
What version of FDRS are you using? Are you still seeing this issue?
